At how much is set your cut off... D16 owners ?
Just like to know because im curious and if you run it more than the original 7200 cutoff .... what have you did to your engine, valvetrain to make it reliable ???
Mat
Mat
Re: At how much is set your cut off... D16 owners ? (yellowturbo)
I ran mine to about 7500 back when it was boosted.. once it saw 85xxrpm (that's over 9k on the tach) on a miss-shift Scarry stuff!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yellowturbo »</TD></TR><TR><TD CLASS="quote">Just like to know because im curious and if you run it more than the original 7200 cutoff .... what have you did to your engine, valvetrain to make it reliable ???
Mat </TD></TR></TABLE>
Mine is set at 7600 because I have such a big turbo. This is on a stock block. Built block I plan on 8000-8300
Re: (yellowturbo)
The revlimit is 7200 as well.. the stock tach is off as the rpm climbs. I know in my GSR and my Civic, the factory rev limit was spot on with the redline as per the AFC, even though my tach would show as much as 300rpm off.
Re: (VTC_CiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTC_CiViC »</TD></TR><TR><TD CLASS="quote">The revlimit is 7200 as well.. the stock tach is off as the rpm climbs. I know in my GSR and my Civic, the factory rev limit was spot on with the redline as per the AFC, even though my tach would show as much as 300rpm off.</TD></TR></TABLE>
I increased mine at the beginning of the summer, no problems yet. If something happens, oh well. Gives me more of reason to put the built motor in.
Edit, no wonder my tach says 8000 when I shift. Are all the honda tachs off?
It's not just Honda tachs, the tach in my DSM is off by about 300-400 rpm at redline.
My buddys Integra's tach reads high too, I'm not sure exactly how much, but I bet it's a couple hundred rpm.
My rev limiter is 8200, stock block and stock head (plus cam). I shift before that though.
Re: (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman »</TD></TR><TR><TD CLASS="quote"> Are all the honda tachs off?</TD></TR></TABLE>
Every one that i've driven to date has been off..
Re: (kpt4321)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kpt4321 »</TD></TR><TR><TD CLASS="quote">
Got mine at 8200 too but it aint a stock block
Re: (D-Man)
So, what should I be shifting at with my boosted y8, only thing done to the head is a 3 angle valve job, and for the block I have eagle rods and forged pistons and a block gaurd.
Re: At how much is set your cut off... D16 owners ? (norcalcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by norcalcrx »</TD></TR><TR><TD CLASS="quote">We rev our built y8 to 9500.</TD></TR></TABLE>
define built
define built
Re: At how much is set your cut off... D16 owners ? (BioXide02)
The z6 redline is at 7600 stock. I rev mine to 7500 stock untouched ecu all day long when slamming shifts w/o hitting any sort of revlimiter. This is all verified as per afc peak + hold function...
