How much power can stock fuel lines support.
I am planning on redoing the engine compartment with 6an ss braided, but I don't what to swap out the lines under the car. How much fuel can they supply, how much power are they good for? Thanks,
New User
Re: How much power can stock fuel lines support. (2K_TEG)
the inner diameter of -6 earls ss line is basicly the same as the stock hard lines.. i have no real idea how much fuel they can push, but im sure you can figure out how much water can be pushed through a pipe that size and then figure out how much actual fuel a certain amount of HP requires (www.rceng.com has the formulas)
Re: How much power can stock fuel lines support. (brian b)
lol the stock line is nowhere near the size of a -6.. its not even as big as a -4
if you push more than 10psi i would use larger than 450's.
and if you got bigger than 450's you are looking at getting larger fuel line...
so i'd say the limit is around 350hp.
[Modified by Sexual Chocolate-616, 11:35 PM 6/12/2002]
Can anyone confirm? Thanks.
Boostfed86
02-12-2009 05:37 PM
