How much lower is Moroso Oil Pan?
New User
How much ground clearance do you lose with the Moroso oil pan. I'm assuming that to hold the extra oil the pan has to be lower to the ground...
New User
Re: How much lower is Moroso Oil Pan? (DarksideDC4)
Moroso quotes no additional depth. It is kicked out in the rear for the additional quart of oil, so you dont lose ground clearance.
Re: How much lower is Moroso Oil Pan? (VaporTrail)
It shouldn't hang any more then like 1cm lower then a factory oil pan. Due to the larger rim on the oil pan/. Where it bolts up to the block.
Re: How much lower is Moroso Oil Pan? (2000_Civic_Si)
Actually this is not true. The moroso oil pan just spreds itself wider at the bottom back beyond the intermediate shft would be. It doesnt really drop any further towards the ground as it would with a domestic car.
