how much head work needed to rev just 1000 rpms over redline?
Old 10-07-2002, 12:58 AM
accordfreak's Avatar
Default how much head work needed to rev just 1000 rpms over redline?
i've been reading about the head through the search i kinda know the answer to my question but i just want to be certain. like the title states.. thanks
Old 10-07-2002, 04:38 AM
New User
brian b's Avatar
Default Re: how much head work needed to rev just 1000 rpms over redline? (accordfreak)
do your valves float now? i dunno much about the accord motors, but my b16a sees 9000 all the time on the stock valve train (dual intake springs rock) for only 1000 rpm a slightly stiffer spring is basicly all you need, you might be lucky and have type-r or gsr springs fit
Old 10-07-2002, 05:15 AM
-CP-'s Avatar
Default Re: how much head work needed to rev just 1000 rpms over redline? (brian b)
theres no point revving more if ur not making power there.
Old 10-07-2002, 06:32 AM
Accord94DX's Avatar
Default Re: how much head work needed to rev just 1000 rpms over redline? (-CP-)
perhaps saving an upshift/downshift on a road course.
Old 10-07-2002, 10:29 AM
Accord94DX's Avatar
bump
Old 10-07-2002, 10:37 AM
What is this crap?
falcongsr's Avatar
if he's boosting, he might have a lot more torque at the wheels at higher redline than if he had to shift.
Old 10-07-2002, 12:12 PM
Default Re: how much head work needed to rev just 1000 rpms over redline? (falconGSR)
well i am planning to build my bottom end. currently i have a turbo setup. my redline is at 6200 so i'm hoping i can make power after 6200 without bending any valves and such. i just want rev a little past redline. so i'm just wondering what would be the basic upgrades of the head to rev about 1000 rpms over redline safely. thanks!
edit: i learned a lot about the bottom end on this board but the head was never really talked about .... so I'm just trying to learn more about the engine head.
[Modified by accordfreak, 9:14 PM 10/7/2002]
Old 10-07-2002, 04:13 PM
Old 10-07-2002, 04:53 PM
niedejb's Avatar
I havnt found any springs/retainers for the F22b1. Good luck.
Old 10-07-2002, 05:00 PM
tk
tk's Avatar
Default Re: how much head work needed to rev just 1000 rpms over redline? (niedejb)
IMO you need better valves and better springs and locks , but like others said why would you go 1000 over redline if you don't make any power after 6000rpm?
Old 10-07-2002, 05:22 PM
niedejb's Avatar
Default Re: how much head work needed to rev just 1000 rpms over redline? (tk)
This is a good point. My max torque is at 4700 and power is at 5800 and then it starts dropping.
Bigger valves might help ya.
Old 10-07-2002, 06:24 PM
tk
tk's Avatar
Bigger valves do make a little more power but not at a higher rpm
The (cams or cam) are what determands the power band
Old 10-07-2002, 06:27 PM
dustin's Avatar
It doen't matter of torque/power falls off unless it is really, really sharp.
You want max torque at the wheels, which means stay in each gear until you absolutely have to shift.
To use this image again:
Old 10-07-2002, 09:08 PM
Default Re: how much head work needed to rev just 1000 rpms over redline? (dustin)
thanks! i've learned something. i guess i'll rebuild my head with new stock parts instead because i don't really want to mess with cams and timing...
[Modified by accordfreak, 6:11 AM 10/8/2002]
Old 10-07-2002, 09:23 PM
TheSwift1's Avatar
The more headwork, the better...
[Modified by TheSwift1, 6:24 AM 10/8/2002]
Old 10-08-2002, 01:46 AM
ion_four's Avatar
Umm...with the turbo the power band will be shifted UP, so the engine will have to rev HIGHER to get it's peak power/optimum shiftpoint. My engine (d16z6) is supposed to make peak HP at 6500rpm, or so, stock...I can gaurantee with my T3 that you would be better off to shift higher, because it still makes very good power up there...however, if his power band was very low to begin with (not familiar with that motor) it might not be necessary.
Old 10-08-2002, 04:15 AM
New User
brian b's Avatar
Default Re: how much head work needed to rev just 1000 rpms over redline? (ion_four)
My shop has a pretty good relationship with ferrea, I can get you whatever springs and retainers you want
tegdude227
11
11-07-2007 11:43 AM
JadeGreenEF9
10-19-2006 09:45 AM
JhorickJFL
02-22-2005 10:05 PM
johncarlos
02-05-2004 11:50 AM
immortal
01-10-2002 05:31 AM
Quick Reply: how much head work needed to rev just 1000 rpms over redline?
