how much boost/hp can my setup handle?
d16y8
Vitara Pistons
h beam rods
NPR Rings
ACL Rod Bearings
6 puck sprung clutch with new pressure plate
10 lbs flywheel
10mm spark plug wires
new spark plugs
new head gasket
arp head studs
motor has just been all the way broken in and gettin ready to start boosting just need some advice
Vitara Pistons
h beam rods
NPR Rings
ACL Rod Bearings
10 lbs flywheel
new spark plugs
new head gasket
arp head studs
Man U FTW
depends on how hard you want to push and what turbo setup you're using...if you have an efficient setup, you should be able reach the upper 300s....
Rather than listing the spark plug wires, you should have given us a little hint as to what you're using for a turbo, manifold, dp, exhaust, injectors, management, etc
Re: (Schister66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Schister66 »</TD></TR><TR><TD CLASS="quote">
Rather than listing the spark plug wires, you should have given us a little hint as to what you're using for a turbo, manifold, dp, exhaust, injectors, management, etc</TD></TR></TABLE>
x2
x2
Re: (stdefhatch)
haha **** my bad i thought i posted it well here it its
what i have for right now is gonna be std manifold with adapter plate 14b turbo has been ported tial 50mm bov jrc fmic(its a big one lol) dsm 450s and im chipped with crome pro
plannin on swaping out turbo an mani later on...just wondering about the setup im gonna be runnin now
