How many of you run stock main bolts on High HP applications?
I know, aftermarket bolts are cheap insurance but I just wanted to know if they are really needed? I mean has anyone actually saw a stock main bolt fail? I am running a b18c1 head, b18a block darton sleeved @ 85mm, with a z10 3 post girdle. As of now for mockup purposes, # 5 and 1 mains have stock LS bolts, and #2,3,4 have GSR's since they are long enough for the girdle. I am looking for around 550 whp and about 9200 rpms.
1 Post
Re: (adSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED »</TD></TR><TR><TD CLASS="quote">run stocks with no problem... otherwise you will have to line hone your block with the arp or aebs mains... gl 550 whp is simple</TD></TR></TABLE>
Not if you torque them to stock-specs.
1 Post
Re: How many of you run stock main bolts on High HP applications? (slowteg550)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowteg550 »</TD></TR><TR><TD CLASS="quote">I know, aftermarket bolts are cheap insurance but I just wanted to know if they are really needed? I mean has anyone actually saw a stock main bolt fail? I am running a b18c1 head, b18a block darton sleeved @ 85mm, with a z10 3 post girdle. As of now for mockup purposes, # 5 and 1 mains have stock LS bolts, and #2,3,4 have GSR's since they are long enough for the girdle. I am looking for around 550 whp and about 9200 rpms. </TD></TR></TABLE>
Get Rid of the girdle, It moves around and beats up the middle 3 main bearings.
Re: How many of you run stock main bolts on High HP applications? (Suprdave)
several of my boys run stock ones with well into the 500-600 range no prob i have a dart block muahahaaaa..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suprdave »</TD></TR><TR><TD CLASS="quote">
Get Rid of the girdle, It moves around and beats up the middle 3 main bearings.</TD></TR></TABLE>
So the girdle doesnt help? I wondered about that, it seems the only way it would help is if you dowel pinned it, to keep it from moving. How high can you rev the ls bottom end w/out a girdle tho?
So the girdle doesnt help? I wondered about that, it seems the only way it would help is if you dowel pinned it, to keep it from moving. How high can you rev the ls bottom end w/out a girdle tho?</TD></TR></TABLE>over 10K is easy
Re: How many of you run stock main bolts on High HP applications? (earl)
depending on the condition and fit of the mains, i have seen engines that had obvious marring where the main meets the block from the cap moving around. arp studs tq'd to arp specs with an align hone generally stop that from happeneing.... is it a problem... i dunno, but moving mains cant be good.
I had always ran stock main bolts on my B16A. On my GSR block I did go with AEBS main studs no line hone and worked fine. We got some changes that RLZ is making on my motor so it may get a line hone if needed now
Re: (Boostfed.com)
i put a set of arp main studs on my gsr and it completely fubared the clearences and the crank didnt want ot spin....
went with stock bolts.....everythings sweet
if you use studs i would get it align bored ....the arp rec torque is 80ft lbs
Re: (D@nnY)
I'm gonna use stock bolts, but still gotta get it align bored, i'm using the gsr girdle and center 3 caps. I don't have the original caps, so any way I go I gotta get it aligned...
Re: (D@nnY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D@nnY »</TD></TR><TR><TD CLASS="quote">i put a set of arp main studs on my gsr and it completely fubared the clearences and the crank didnt want ot spin....
if you use studs i would get it align bored ....the arp rec torque is 80ft lbs </TD></TR></TABLE>
if you read the arp instructions, it says to get an align hone
Re:
Have the arp main studs the same threads on the nuts as the stock mainbolts? if not the pressure on the mains can be different regardles if the same turque is used on the arp´s and stock ones..
Re: (JDogg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDogg »</TD></TR><TR><TD CLASS="quote">
if you read the arp instructions, it says to get an align hone </TD></TR></TABLE>
yes it does..it says to align bore it with the mains torqued down to 80 ft lbs
Re: Re: (The sweed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The sweed »</TD></TR><TR><TD CLASS="quote">Have the arp main studs the same threads on the nuts as the stock mainbolts? if not the pressure on the mains can be different regardles if the same turque is used on the arp´s and stock ones..</TD></TR></TABLE>
the stock main bolts dont use nuts...they are just bolts
arp studs are a bit scarey: after the line hone loosen the nuts, then retorque them and dial bore the main saddles again. hmmmm, different size. do it again. same thing. several blocks with the same issue. the only way we could fix it was to lower the torque to near stock. anyone else measured the saddles and seen this?
Re: (RMS)
i have seen several blocks that do this with stock bolts as well.. most of the time when i see that the dowels that locate the caps in the block are slightly loose.
