how many miles on your turbo before something broke?....
just as the title says, how long did your turbo go before something broke and money webt out the window.
bte, please list the miles you had
tia
tia
New User
Re: how many miles on your turbo before something broke?.... (ekb18c)
I went about 50 miles on the LS piston'ed B16a... then it melted 2 because of too much boost for stock injectors. Oops.
Now we built the motor, and I cannot keep a clutch/tranny in it at 8psi with a standalone that's untuned!
Re: how many miles on your turbo before something broke?.... (CivicNewbie)
Mine broke before the turbo even went in!! Guess I have a fresh new b16 to boost now.. I'll let ya know when I blow this one up, too.
https://honda-tech.com/zeropost?cmd=reply&id=1327503
New User
Re: how many miles on your turbo before something broke?.... (bocian)
5 miles.
I lost an oil line the first 5 miles. Next failure:
3 more miles.
Exhaust connection came loose. next failure:
100 miles.
Burned up the stock clutch. next failure:
1000 miles.
Stock fuel pump gave up the ghost. next failure:
10 miles.
New fuel pump overfuels and fouled plugs while blowing fuses.
I am just kidding about the actual miles, but be prespare to do minor repairs all the time.
Randy
3 more miles.
100 miles.
1000 miles.
10 miles.
Randy
Will you make something up for me please?
Re: how many miles on your turbo before something broke?.... (RGAZ)
About 5K miles then spun a rod bearing.
Rebuild was completed last night!!! The motor started on it's first try. I just need to finish my exhaust and bleed the clutch lines.....then it's off to it's 3K mile break in!!! Woohoo!!
Re: how many miles on your turbo before something broke?.... (shamoo)
7k miles: Charcoal canister blew a hole somehow
8k miles: IAC valve plugged with ALOT of dirt (not running filtered turbo..should though)
Snafu-Si
05-07-2002 02:23 PM
