how to make EGT readings lower?
when i race someone, my EGT goes high 800's (c), and if i raced even harder, im sure it would come REAL close to 900 or more. so my question, is how to have the readings become lower? car is already tuned.
Re: how to make EGT readings lower? (gsR-T mode)
add fuel or advance timing.
but we really need full setup description including a/f ratio. |
post a pic of where the probe is at, mine is in the #1 runner, and i'm 1300-1400 when i get on it
Re: how to make EGT readings lower? (falconGSR)
add fuel or advance timing. but we really need full setup description including a/f ratio. 98civicex, I think he means celsius and you mean fahrenheit... 1500ºF~~900ºC [Modified by ion_four, 7:08 AM 7/1/2002] |
Re: how to make EGT readings lower? (98civicEX)
mine is a custom manifold, and it is right in the middle.
add fuel or advance timing. but we really need full setup description including a/f ratio. I wouldn't give it too much thought.. See ya, -Jason |
Re: how to make EGT readings lower? (ion_four)
add fuel or advance timing. but we really need full setup description including a/f ratio. umm...shouldn't he retard timing? No, Retarding his timing will actually raise his EGT, because he will be flowing a les burned mixture down his exaust which will burn in the pipes, instead of the combustion chamber where it should be... -Jason 98civicex, I think he means celsius and you mean fahrenheit... 1500ºF~~900ºC [Modified by ion_four, 7:08 AM 7/1/2002] |
Re: how to make EGT readings lower? (TurboCivicSi)
that would be correct, my car was wideband tuned with the hondata.
ohh, and as far as spiking, i have a boost cut off. [Modified by gsR-T mode, 6:28 PM 7/1/2002] |
High EGT's under normal conditions mean either too rich or too retarded ignition timing. If a/f is correct, then more timing would be needed to bring it down.
that would be correct, my car was wideband tuned with the hondata. ohh, and as far as spiking, i have a boost cut off. [Modified by gsR-T mode, 6:28 PM 7/1/2002] |
Re: how to make EGT readings lower? (VaporTrail)
I'd say advance the timing a bit, but this causes pinging to occur unless you are running slightly higher octane. I always tune rich, than watch the egt's...they are then almost always based upon timing settings.
High EGT's under normal conditions mean either too rich or too retarded ignition timing. If a/f is correct, then more timing would be needed to bring it down. |
Re: how to make EGT readings lower? (B20C5 Turbo)
my EGT's do stay between that range most the time. but im talking about when you get on it for many many seconds.
Simple question I have:
I am a turbo user w/o an egt gauge (soon hopefully). Obviously people mention about different grades of gas. Has anyone ever noticed different egt readings by using different brand gas. Say going from sunoco 93 to mobile 93. Anyone ever see a difference in the same grade but a different seller? Hmm....makes me wonder. |
my EGT's do stay between that range most the time. but im talking about when you get on it for many many seconds. My daily driver (A fully dressed Integra GSR w/Leather, AC, 6 speaker stereo, and Power everything) will accelerate from 0~120mph in 11.8 seconds. At 145 mph (less than 8 seconds later) it begins to go airborne. The whole trip from 0mph to "lift-off" occurs in less than 20 seconds, and never exceeds 1500F exhaust temps. Talk to me.. What exactly are you doing there? [Modified by B20C5 Turbo, 1:50 AM 7/11/2002] |
Re: how to make EGT readings lower? (93LSivic)
Has anyone ever noticed different egt readings by using different brand gas. |
how's chevron? too bad we only get 91 here in cali
pretty much for about 1/2 a mile maybe 1 at the most. this is at FULL throttle, the temp. goes up to close to 9. obviously that is not too good, so after the first time i noticed that, i refrained from doin it.
you're at WOT and full boost for 1/2 to 1 mile?
