how is his set up for a b18c (stock)
TDO5 16g turbo
internal wastegate
flanged b-series manifold
Downpipe
fat polished JRC FMIC
various oil and cooling lines
piping
RC 550CC injectors (brand new)
blitz blow off valve
boost gauge
air fuel gauge
a-pillar dual gauge pod
blitz turbo timer
walbro fuel pump (brand new)
FMU
missing link
will i be running out of room....
and what would you pay for this??
internal wastegate
Downpipe
piping
boost gauge
air fuel gauge
blitz turbo timer
FMU
missing link
Re: (93turbo16)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93turbo16 »</TD></TR><TR><TD CLASS="quote">You have some decent parts in there. The 16G should work OK, but not the best on that particular setup. But you are definitley skimping on the fuel management. With the 550s, you will want to run some type of management ( uberdata, crome, hondata, ect)</TD></TR></TABLE>
so what would u expect to pay for this... knowing the management sucks and the turbo could be better..
TSPeed Factory
Re: (93turbo16)
running 550cc on that with FMU will dump a **** load of fuel. all you need now is a rechipped p28, hondata/crome/uberdata/etc. and a tuner and you're in business.
Re: (AzntaggeR)
if u are running a stock b18c then your still running the stock IM i take it? then u cant run a P28 ecu its not set-up to run the butterflys in your IM. get yerself a obd1 p72 have a local shop burn u a base map on it uber,crome ect.... the injecotrs are just fine but run yer stock ones until u get it to your tuner. its hard to make a base map off of anything but stock injectors. GL
Re: (mattcivic)
Definitely look into Crome or Uberdata - engine management and tuning is the only way to make the engine run good and be reliable. I'd say keep the 550's; you'll have a little more room to work with if you upgrade to a larger turbo, and won't have to run them near what I hear is a dangerous duty cycle of >90%.
Re: (mattcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattcivic »</TD></TR><TR><TD CLASS="quote">if u are running a stock b18c then your still running the stock IM i take it? then u cant run a P28 ecu its not set-up to run the butterflys in your IM. get yerself a obd1 p72 have a local shop burn u a base map on it uber,crome ect.... the injecotrs are just fine but run yer stock ones until u get it to your tuner. its hard to make a base map off of anything but stock injectors. GL </TD></TR></TABLE>
IN stock form, it can't control them. But just about any one that chips ecu's or sponsor's the site can add IAB support. I know I do at no extra cost if it is needed.
Also it is not hard to make a basemap for bigger injectors. Yes they act differently then stock injectors so linearly scaling them sometimes give you odd idles and what not. But if you leave the O2 in there, it is perfectly fine driving 100 miles to a tuner. I have a lot of people who drive to me on basemaps from over 2 hours away.
And PS: After you turbo your car.. your intake/header goes out the window... that is what the turbo is there for.
Re: (93turbo16)
I personally think that that turbo is too small.. The stock b-series engines like to put out power boosted.. Look into either a T3/To4e or a GT28RS..
The pretty light display(autometer air/fuel gauge) is just a waste of money.. Also you dont need to mention about the A-pillar pod.. If you want a real wideband for your pillar then get an AEM gauge type UEGO wideband..
Re: (tgreaves)
i never knew u could this. thanx for fillin me in.
Re: (mattcivic)
i never knew u could this. thanx for fillin me in. </TD></TR></TABLE>
No problem. Not many people know how to do it. So the word doesn't get out as much.
Re: (gapergurlie_18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gapergurlie_18 »</TD></TR><TR><TD CLASS="quote">TDO5 16g turbo
internal wastegate
Downpipe
piping
boost gauge
air fuel gauge
blitz turbo timer
FMU
missing link
If you are gunna run the 550's then you'll also need to run a obd1 p72 or p28 socket/chipped ecu chipped for your choice of what ever program your tuner is more comfortable working with.also make sure your walbro pump is a 255 lph.
P.S. ditch the FMU and missing link
internal wastegate
Downpipe
piping
boost gauge
air fuel gauge
blitz turbo timer
FMU
missing link
Re: how is his set up for a b18c (gapergurlie_18)
check the classified section for some used hondata. Im confused about what 1300 is quoted for? i hope its not the uberdata with the basemap, because uberdata is free. But yes definetly ditch the fmu and misssing link and get a good tune.
problem is that there is no good tuner where im from... it will have to go on a boat to get to the next islnd over for a tune... ~300 bucks there and back. so thats another problem.
Location: The Village Hidden in the Leaves: Seattle, WA
personally. i would ditch the td05 16g turbo. go with a hybrid t3/t04e at the least. your motor will be able to handle it.
i've ran both a .48a/r and a .63a/r t3/to4e's on my gsr. the .48 is great for street cause it's a quick spool. the .63 take a little bit longer, but it hauls ***!
you won't need the fmu and missing link if u go with 550's. just get a chipped ecu. i got mine from 93turbo16
superturboprelude
09-02-2005 06:12 PM
hj
10-07-2003 05:43 PM
RATEDR
06-07-2002 02:29 PM
