How high is your redline??(boost sohc)
Old 05-07-2009, 07:56 PM
charlie_sohc's Avatar
Default How high is your redline??(boost sohc)
how high are you guys reving your sohc vtec too? Also what set up on your vavle train and cams. I got a 59500 zex with super tech springs, etc...boosting 20psi a e85 with a build bottom end. so far i just reving it to 7800 only. I want to see who is reving up higher and is it safe to go higher? thanks
Old 05-07-2009, 08:04 PM
spectacle's Avatar
Default Re: How high is your redline??(boost sohc)
Post a dyno and we'll tell you whether you need to go higher.
Are you falling out of boost between shifts?
Old 05-07-2009, 09:10 PM
with out the cam i fall out of boost with the readline at 8000 before but with the cam @7800 it does not fall out of boost... so far no dyno yet...just street tune..
stevenmannn
09-03-2009 10:52 PM
danno33
16
11-03-2006 12:39 PM
dnrprojectsvp
Northern California (Sales)
07-28-2006 12:43 AM
teamrushhatch
06-03-2003 12:23 PM
Quick Reply: How high is your redline??(boost sohc)
