how does your turbo do with gas mileage?
i was wondering how far do your turbo setup go with a full tank of gas...or miles per gallon...and would you recommend turbo for a daily driver?
OG triple OG
Re: how does your turbo do with gas mileage? (cmGSR916)
on my fully built y8 turbo.....
it takes me 190 miles to get from my moms house in walnut creek , down to my navy base past fresno......and if i fill up in walnut creek it takes me a little less than a quarter tank to get there.
Re: how does your turbo do with gas mileage? (95GSRTT)
220? Obviously you don't boost a lot when you beat on it, because mine gets about 150-200 when I floor it a lot (like all the time). But that's pretty much what it was NA. Same goes for if I take it slowly, about 300-350 a tank.
Re: how does your turbo do with gas mileage? (EG-CRAIG-R6)
on the highway I can drive all day long, about 280 on a tank full.
In the city it is unreal. I have used up 1/4 tank in 1/2 hour! the rx-7 injectors dump in a ton of fuel when I boost, but I havent fine tuned it on the wideband so Im super rich.
My EF with the utterly repulsive combo of B16 motor and LS trans will nail down about 25 MPG on the highway if I don't boost. Considering how depressingly long the LS trans gears are, that doesn't happen much.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">roughly 300 miles a tank in my integra....If i beat the **** out of it on high boost, it goes down to probably 220</TD></TR></TABLE>
About the same here. Made it from San Diego to Primm, Nevada on a little more than 3/4 of a tank.
Re: (Turbo E 604)
D14A4
12liter/100km - which makes it about 20mpg
Same in city/open road... in city I drive a bit 'faster' (hitting boost all the time), and on open road about the same (most of time over 100mph).... driving usually rather fast. Lowest I got it on open road was 9.5lit/100k (~28mpg) but this was also rather faster that rest of traffic... I just can't bring myself to drive slow
Re: how does your turbo do with gas mileage? (97hb)
I usually don't let the tank get lower than ~3/4 empty, but I get 32 mpg city, ~40 mpg highway, and the ocassional ~28 mpg driving like an idiot.
set up (b20/ ls trans, @ 10 psi, hack)
I know it sounds like BS, but I'm a really conservative driver ( I rarely ever give it more than ~15% throttle ). What I'm getting now is the same as when I was NA.
I used to get a little better when I had the stock d16z6.
Re: how does your turbo do with gas mileage? (squirrel)
it's not the turbo itself that gives you bad gas mileage..it's you wanting to hear the bov nice and loud every time you shift
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">So how exactly are you getting better gas mileage than stock while boostin?</TD></TR></TABLE>
Because, ever try getting up a hill with a low power NA motor? You have to ride the throttle longer to make it up the hill. When you have more power, you will not have to give it as much throttle to make it up to speed.
Re: how does your turbo do with gas mileage? (Bailhatch)
Wow, I get a little more than 400 to a tank if I baby it, about 320 or so if Im having fun This is in my EF with y8 swap and IHI turbo at 8lbs
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95GSRTT »</TD></TR><TR><TD CLASS="quote">So how exactly are you getting better gas mileage than stock while boostin?</TD></TR></TABLE> The car is runnin more efficent and you don't need to push the pedal down as much to go some where!
