How does this oil return like look? Pls take a look.
Location: South Bay, Torrance/Carson, CA, United States
This is my first turbo install and I'm learning as I go. My turbo doesn't really have a problem with smoking and I don't want it to start. So please take a look at my return line and give me some feedback. The fitting is welded into the oil pan so that limits my options. As you can see after the bend its a straight shot into the oil pan.
Any suggestions or comments are appreciated.
Modified by South Bay Surfer at 11:29 PM 7/22/2008
Modified by South Bay Surfer at 6:33 PM 7/23/2008
Re: How does this oil return like look? Pls take a look. (Dartanian)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dartanian »</TD></TR><TR><TD CLASS="quote">Looks good. Personally, I would use a 45 degree fitting and shorten the line a bit.</TD></TR></TABLE>
I wish I would have thought of that before I got this fitting welded in there. I actually already shortened the line quite a bit. You should have seen it before there was a bit of upward travel. There isn't any upward travel anymore. The part I'm most worried about is the 2 inches of straight travel into the pan. But I'm thinking the downward momentum of the oil will push it right into the oil pan.
Re: How does this oil return like look? Pls take a look. (South Bay Surfer)
i was worried about this with my setup but it never seems to be an issue. but i will be putting a 45 on the pan next time i have everything apart to be 100% sure.
find another oilpan and get a bung welded in there (if youre using NPT fittings you can usually find something thatll work in the air compressor aisle of your tool store)
No oil restrictor because I'm using -3an feed line. How do I find out whether I have good crankcase ventilation?
Re: (South Bay Surfer)
Get rid of your stock PCV system and install a catchcan. Big crankcase pressure will make your turbo return line worthless.
if youre broke then just take out the PCV valve and vacuum line that goes to the intake manifold and let it dump crankcase pressure into atmosphere. search crankcase ventilation for more hints
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by South Bay Surfer »</TD></TR><TR><TD CLASS="quote">
I wish I would have thought of that before I got this fitting welded in there.</TD></TR></TABLE>
I was referring to the fitting off the turbo. It is fine how it is, though, so I wouldn't stress over it.
I was referring to the fitting off the turbo. It is fine how it is, though, so I wouldn't stress over it.</TD></TR></TABLE>
Would adding the 45 degree fitting at the turbo greatly improve the oil drain?
THanks for the help Do you have a link where I can purchase the 45 fitting for the turbo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by South Bay Surfer »</TD></TR><TR><TD CLASS="quote">THanks for the help Do you have a link where I can purchase the 45 fitting for the turbo?</TD></TR></TABLE>
Don't worry about it, you don't have a problem with the way it is. You're about as vertical as you can possibly get.
Re: How does this oil return like look? Pls take a look. (95dc2teg)
THanks for all the replies. You all have put my mind at ease. This one's for you
Re: (BDaTurboTeg)
No kink in the line, line doesn't angle up to get into the oil pan. Looks good to me!
Personally, I'm not too big of a fan on barbed fitting into the oil pan. They tend not to seal completely and leak a couple drops every now and then.
Re: (viet_boi_racin)
never had one leak on me. I am using the pushlock fittings. you have to make sure the line is quite a snug fit onto the barb. Usually using a hose clamp makes things worse.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viet_boi_racin »</TD></TR><TR><TD CLASS="quote">
Personally, I'm not too big of a fan on barbed fitting into the oil pan. They tend not to seal completely and leak a couple drops every now and then.</TD></TR></TABLE>
If you install it correctly it won't leak.
Re: (CRXdan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXdan »</TD></TR><TR><TD CLASS="quote">Get rid of your stock PCV system and install a catchcan. Big crankcase pressure will make your turbo return line worthless.
if youre broke then just take out the PCV valve and vacuum line that goes to the intake manifold and let it dump crankcase pressure into atmosphere. search crankcase ventilation for more hints</TD></TR></TABLE>
I'm broke so how do I do this? Do I plug the intake manifold and just let the PCV valve vent or do I remove the PCV too? This is until I get the catchcan.
RyanAutry
05-06-2003 12:37 PM
