How do I modify my starion FMIC to work?
How do I weld on the end pipes? Is it easy?
Am I better off going to somebody for this? or should I save the cash and pull a DIY move?
LMK
Thanks
LMK
Thanks
Re: How do I modify my starion FMIC to work? (racinskittle)
Well its aluminum. Whoever does it needs to be comfortable and have some experience welding aluminum . You will have to cut a hole in the sides and weld in the new inlet and outlet. Then plug up the holes on the top of it.
Re: How do I modify my starion FMIC to work? (omahaturbocivic)
or just run ur pipes all crazy-like until they fit
hehe or like said above plug old holes, make new ones, have pipes welded on.
good luck
good luck
Re: How do I modify my starion FMIC to work? (Pengo)
dont try to stick weld new end tanks, it's damn hard!
(i tried it for fun, no argon in the bottle, so dont ask) lol
Re: How do I modify my starion FMIC to work? (lazerus)
you can go to home depot get those 1.75 inch silicone 90 degree bends. first you have to cut the pipes shorter about 1.5-2.5 inches. ill show you pixs if you dont understand
Re: How do I modify my starion FMIC to work? (InTeGrA B18b1)
fantastic thanks. Just curious, what do i use to make the holes? And do I make them any place on the sides?
JB Weld worked for me!
I used JB Weld on my SOHC turbo to 10 psi it was holding great up untill I pulled the engine. and it is still leak free to this day.
its the ghetto way to do it, but it worked great.
