How do i get the exhaust housing off??
I am trying to get the exhaust housing off but the bolts are hitting the center section like the oil feed hole and the oil return. Can i rotate the housing? i tried and it would not move. any suggestions?
Re: How do i get the exhaust housing off?? (D 2da A9)
if you loosen all the bolts already and it still wont turn...then its sieze...take sum cleaner and try to get the dirt off around that area and see if it will budge....if not...take a RUBBER mallet and lightly tap around the housing til it comes loose...but be careful... u dont want to bend or break ur blades
Re: How do i get the exhaust housing off?? (iBrandon)
i pulled the housing off little by little as i loosened the bolt. If all else fails, try to clock it with a BFH!!!
Re: How do i get the exhaust housing off?? (boostedej1)
ok i got it loose. took some hammerin. now, how the explective do i get the compressor wheel off??? the nut is off and it is still verry tight. do i have to screw it off? sorry never tooken apart a turbo before.
