How can you tell when you boosted too much?
what are the differences between running a cylinder lean, or using too much boost? I have a friend that has cracked the ring lands of his pistons...it sounds like too much boost to me. How can you tell you ran a cylinder lean?
Re: How can you tell when you boosted too much? (PressurizedSi)
running lean and using too much boost is totally different. He probably ran lean causing the motor to detonate cracking the rings. Running a lot of boost won't detonate a motor, having little to no fuel will. As well as running too much timing advance.
Judge Owens
02-28-2015 06:00 PM
