stock itr with 50 trim, psi and whp
Old 02-22-2011, 02:44 PM
racebum's Avatar
Default stock itr with 50 trim, psi and whp
i've spent about two hours on google trying to find dynos on this BUT, none seem to be had
anyway, my question is with a a 50 trim t3/t4 like the garrett with a stage 3 wheel or precision 5031 or 5431 what kind of pressure is needed to arrive in that 280whp to 300whp range.
easy as **** to find answers for an LS or gsr but the 11:1 of the jdm itr there isn't jack on the net.
reason i ask?
1. wastegate spring
2. map sensor if it needs to be upgraded
Old 02-22-2011, 03:01 PM
Ryank327's Avatar
Default Re: stock itr with 50 trim, psi and whp
I'd take whatever the average it takes a GSR to get it and take about 2 PSI off of there and you should be close.
Old 02-22-2011, 03:07 PM
racebum's Avatar
that's my best wild *** guess as well. that of course means 8-9lbs which would be a .6bar spring
hope someone has actual data, it has to exist somewhere
Old 02-22-2011, 03:11 PM
AlexDphoto's Avatar
imo you should just upgrade your map sensor to begin with. theyre pretty cheap!
Id say a good 9-10lbs through that turbo should get you there.
On my ported and polished gsr on a 3255 I made 293 on 8lbs. of course there are many other factors and thats at 10:1
Old 02-22-2011, 03:16 PM
Ryank327's Avatar
If I'm not mistaken a GT28RS is somewhat comparable to what you are looking for. If so I remember a dyno on evans tuning site of a Mini with an ITR swap doing 295 at 10 PSI with one.
I'd say 8-10 PSI also should land you around where you want. If you want to be cautious with power for some reason go with 8, otherwise I'd just run 10.
Old 02-22-2011, 03:33 PM
racebum's Avatar
that's a good point on the map
as for the other factors
inline pro ss and a full 2.5" exhaust, may run a 3" dp depending on clearance with the rad fans
Old 02-22-2011, 04:31 PM
AlexDphoto's Avatar
Got my gm 3 bar for $30. thats like staying and eating in 3 times every paycheck instead of going to applebees LOL
Old 02-22-2011, 05:30 PM
racebum's Avatar
where at? i think i still have an OEM map from a 1991 corvette in the shop, are those things actually compatible?
Old 02-22-2011, 07:52 PM
bgdriver's Avatar
LOL nothing is NOT compatible. It just looses cost/value.
Old 02-23-2011, 06:44 AM
03EM2guy's Avatar
i have a gsr with itr pistons and rods and stock b16 head ...cp ~11.0:1
and made 297whp / 220 ftlbs on 10.5psi with a godspeed .50 trim .57a/r hotside
...loaded dyno ..was told it reads a little bit lower than a mustang dyno
Old 02-23-2011, 08:06 AM
Moderator
TheShodan's Avatar
Mustang Dynos are load-bearing dynamometers.
Mobeious
12-20-2012 06:33 PM
blackeg
10-23-2011 02:21 PM
skUnK2jdm
12-02-2007 05:21 PM
b16bri
11-18-2007 04:18 PM
hatchinprogress
12-23-2005 03:52 AM
Quick Reply: stock itr with 50 trim, psi and whp
