hondata s300 and boost control? HELP ASAP
i've got an hondata s300 that i bout off of boosted96teg and hes not responding to me anymore and i need help. i got a couple of questions.....
1. I need instructions on how to hook up precision 1000 cc injectors to my car i have the obd1 clips and the resistor box but i need help hooking them up.
2. Will the stock fuel rail handle a walbro 255 and 1000 cc injectors running 10 to 15 psi?
3. the hondata s300 controlls my boost. with that said i have two wastegates and i have all the vaccum lines hooked up but there is a sylinoid hooked in the middle of the vaccum lines and i need too hook it up to hondata s300 i think thats where he had it hooked up to and i need to know if this is correct? i think he had it hooked there but the wires are different color and i want to make sure this is how i hook it up b4 i mess something up big time.
4. he was running a base map of 28 psi on race fuel and i need to get it down to a base map of 10psi so i can drive it to the dyno can anyone help i have downloaded the software and just need help on getting it down so i can drive it without worry.
5.i have a gm 3 bar map sensor i need hooked up also any help?
PLEASE HELP ME I NEED TO GET THIS THING RUNNING ASAP SO I CAN GET IT TUNED!!!!!!!!!!!!!!!
THANK YOU FOR YOUR TIME AND PATIENCE AND IF IT WOULD BE BETTER TO CONTACT ME SO WE CAN TALK PM ME AND I CAN GIVE YOU MY CELL PHONE NUMBER AND YOU COULD CALL NOW!!!
1. Wiring diagrams on http://www.phearable.net/tech
2. Yes
3. Look at the diagram on http://www.phearable.net/tech
4. Talk to your dyno tuner.
5. Talk to your dyno tuner.
2. Yes
thank you so much i got ahold of him and he helped me some but i am glad you gave me this information to look over so i can hook it all up i really do appreciate your help!!
