hondata s300 anti lag?
Tony1 owns me!
has anyone got this to work, i have not had any luck. i can up the fuel and pull all the timing and it still does the same thing.
Re: hondata s300 anti lag? (InJ3cted)
For proper ALS operation, timing needs to be retarded to ATDC in order for combustion to start once the exhaust valves are open. Use fuel to keep EGTs under control.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InJ3cted »</TD></TR><TR><TD CLASS="quote">As far as s300 then... is there not a "proper" way of using Anti-lag would it just be considered a 2 step or 3?</TD></TR></TABLE>
True ALS setups require some way to bypass air around the throttle body while off throttle. Hondata offers a 'drag style' antilag rather than a traditional rally style ALS. The Hondata setup is simply there to build boost before launching, as opposed to maintaining boost pressure while off throttle.
Re: hondata s300 anti lag? (nfn15037)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dreadcivicturbo »</TD></TR><TR><TD CLASS="quote">are u putting in the retard value as a negative number...eg -20</TD></TR></TABLE>
theres a retard & fuel enrichment box, I dont know how much to retard or how much fuel to add
theres a retard & fuel enrichment box, I dont know how much to retard or how much fuel to add</TD></TR></TABLE>
Experiment and keep an eye on EGTs and the boost gauge.
Re: hondata s300 anti lag? (Meat_Wagon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Meat_Wagon »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothread?id=1716839</TD></TR></TABLE>
Thanks... I tried searching a whole bunch of keywords on ht search but that thread never popped up thanks man
allmotorpackage
Engine Management and Tuning
17
04-12-2011 10:45 AM
