Hondata s200 Work With Motorola 2.5bar MAP Sensor?
Re: Hondata s200 Work With Motorola 2.5bar MAP Sensor? (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber »</TD></TR><TR><TD CLASS="quote">It does with romeditor v4. It does not with romeditor v3</TD></TR></TABLE>
Hmm... Since I don't tune, I guess that's a question for the tuner?
Soooo... Any idea why this is??? Isn't a MAP sensor signal a MAP sensor signal??
Re: Hondata s200 Work With Motorola 2.5bar MAP Sensor? (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">
Soooo... Any idea why this is??? Isn't a MAP sensor signal a MAP sensor signal??</TD></TR></TABLE>
Hondata does not allow you to use a custom map sensor scalar or a 2.5 bar in romeditor v3. If you have a problem with this, contact them & they will tell you to upgrade to romeditor v4.
Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">I guess this might be the reason why people run neptune, crome & the like?
Sure wish I knew this before I ordered the Moto MAP. </TD></TR></TABLE>
No, they run crome because they are cheap lol :-)
They run neptune because they like it's features and the name.
Its all in personal preference.
I was reading on Hondata's forum that the s200 with romeditor v3 will work with a "Motec" MAP, however, I've been on Motec's site, but I'll be damned if I can find that sensor....
Re:
romeditor v3 does support a 3 bar and a 5 bar... romeditor v4 adds the option for a custom map sensor which you can use to setup any others.
or your other option would be to sell the s200 and change over to an s300...
We talked about that before, and it's becoming more and more of a viable option...
I just like having the ability to plug in the laptop and bring up the Hondalogger to look at all of the pretty pictures...
Would I need to step up to the Neptune rtp to retain these things?
Re: (B18C_EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">We talked about that before, and it's becoming more and more of a viable option...
Would I need to step up to the Neptune rtp to retain these things?</TD></TR></TABLE>
Neptune also has a "Neptune Logger" for non rtp users, however you will need to get your self a datalogging cable.
Re: (mtber)
Neptune also has a "Neptune Logger" for non rtp users, however you will need to get your self a datalogging cable.</TD></TR></TABLE>
Interesting! Any screenshots?
Re: (B18C_EJ8)
Why not buy a used AEM unit? It has all the features you'd want, plug and play, and has the port for you to plug into and has datalogging already, and accepts pretty much every MAP.
I'm trying to recall which model I have, but I've been debating on selling it since I'm not boosting now. It is from my OBD2b EM1. Just let me know.
Re: (blaze the chemi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blaze the chemi »</TD></TR><TR><TD CLASS="quote">Why not buy a used AEM unit? </TD></TR></TABLE>
AEM unit is more than Hondata and Neptune put together...
