Hondata IM Gasket ?s
I recently purchased the hondata gasket and have a couple of questions on it. First off will my stock studs work with it? If not where can I get new ones from. Also if I decide to cut the hole out for the coolant flow will it even make a difference? And if i do cut it out how will this affcect every day driving. Any info will be greatly appreciated. Thanks
Re: Hondata IM Gasket ?s (Boosted99Si)
honda makes a stud that is just a bit bigger, thats what i used, i keep the coolant flow since i live where there is winter. I get intake temps no higher than 120 even after a big run.
Re: Hondata IM Gasket ?s (GruvyTune)
Aight kewl...thanks for the fast reply.....do you happen to have the part number on these studs.
Anyone ever fit the hondata IM gasket onto the LS motor? I would like to add that to the rebuild. How hard could it be???
