Hondata+Hondata Nitrous Setup= Major issues???
has anyone had any major issues setting up thier nitrous thru the hondata s200?
i was converting my wet kit to a dry kit and was gonna run it thru the hondata to make things a little simpler for me.
but when i followed thier diagrams like they posted. my solinoids were on as soon as i turned the key
i wired it both ways like they have it, and fried a solinoid, so i switched to using LEDs in place of them cause they cost less! but no matter what i did, swapping relays, re wiring, changing the outputs. it never would work correctly
anyone else had this issue?
yes is did search and i searched the hondata site too, but never got a clear answer
Re: Hondata+Hondata Nitrous Setup= Major issues??? (mrbsponge)
same thing happened to me when i was using the n2o cooler. never figured it out and hondata was no help... they said it was the wiring which it wasn't, then the ecu sent it back to them to check and they said it was fine. I ended up selling the kit because i got so frustrated
yeah i rewired it like 15 times, and swapped out a bunch of relays, im staring to think its not my wiring but thier diagram, and that dumb jumper thingy they have on it. i have hooke up plenty of kits, and plenty of relays.
we swapped in like 5 different P28s and 1 P72, so i know its not the ecu
