Hondata on a B18B CRX? And High Boost Fuel Mangment Q's
Aight My Bro and I are gettinn ready to put in a built B18 quick Run Down
GE block 84mm
CP Pistons 9.0 CR
Eagle Rods
OEM Block Girdle
Port And Polished Head
ITR Intake Manifold Mod. to Fit
Duel VS, Ti Ret.
Crower Turbo Cams
Aight now We need a Fuel Set up Zndyne and Hondata are at the Top of the list I just want some feedback from people. I like Hondata but not sure if we want to have to buy a Jumper and all that crap but cost is a Tad better. So let it begin.. Thanks for any Help. We are hope for 300 hp range and can turn it up around 8/8.5k.
GE block 84mm
CP Pistons 9.0 CR
Eagle Rods
OEM Block Girdle
Duel VS, Ti Ret.
Crower Turbo Cams
Re: (IntegraXSi)
i had a hondata 4b setup in my crx and ended up selling it because it was impossible (for me and a few others) to datalog air/fuel ratios correctly using a wideband o2 sensor. This made it very difficult to street tune and i was never confident in the tune that i had. the same 4b unit would log values on obd-1 cars just fine but when it came to the obd-0 it seemed that there was something a miss. I even changed over to an obd-1 p28 and continued having the same problem. Another member by the name true has also experienced the same problem and has been living with it for over a year. you can IM him to get his opinions. There is another member by the name speedphreak who is using a zdyne and fjo wideband combo on his crx but I believe zdyne lacks datalogging all together. I chose to go with the aem ems and use an obd-0 to obd-1 conversion harness that I already had from the hondata adventure. HTH
H23ludedude
05-05-2002 09:03 PM
