honda injectors going in extra injector holders, bosch or rc style?
as i said in a earlier post, but prolly wasn't soo clear. will bosch or RC injectors fit the same? i'm buying injector holders to be welded onto the intake manifold and need to know if it will be bosch or rc style injectors that are going in them......whats really going in them will be my injectors from my 99 accord 240cc injectors. so what type are honda injectors.....BOSCH or RC style?
these are the injector holders.
what type are the stock honda injectors.....bosch or the rc type? stock oem injectors off of my 99 accord will be used togo into these injector holders. so i need to know if the oem honda injectors are bosch or rc type.
the injector holder above are the ones that are going to be used, BUT before i order them, i need to know if the injectors going in these are bosch or rc type.......it would suck to buy these INJECTOR HOLDERS as rc type and then my stock oem honda accord injectors dont fit them because they are the bosch type, ya know what i mean?
Re: (Flashmn)
Thats likely the only real diff. Bosch is a 14mm o-ring, and Honda uses a ~12mm o-ring. I'd bet that the RC style is the 12mm o-ring, as RC injectors are drop-in for honda apps.
Re: honda injectors going in extra injector holders, bosch or rc style? (b_ron007)
i have a set of rc injectors i could take measurements to compare...but i'll do that tomorrow
and ot but wtf is that pictured with the injector in your first pic?
Re: honda injectors going in extra injector holders, bosch or rc style? (CivicVX94)
thats the machined injector holder, it sandwiches the injector in there, the top is threaded for a fitting, so like doing a nitrous setup, you feed them fuel like doing a nitrous setup. it'll be welded to the bottom runners of my F23 intake manifold.
come on......no one can tell me what type the OEM HONDA INJECTORS ARE? i need to know so i can tell them what type of injectors are going in, bosch or RC.......i'll have to order the holders according to weather the OEM injectors are bosch or rc type.....the holders are machined different for the different type of injectors
