holset h1a, anybody heard of it?
something different
1 Post
i can pick up a holset h1a for a decent price.....brand new/in box.
i havent seen one of these turbos in person, and i cant find a whole lot on here or anywhere else i frequent about the h1a. it seeems smaller than the hx35, which is a good thing for my application (d16a6, vitara pistons, eagle rods, ported head)
i read the h1c is the "little brother" of the hx35. thats as close as i got. anybody know about the h1a? thanks! -adam
Re: (drumking15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drumking15 »</TD></TR><TR><TD CLASS="quote">itll be to big for your app...youd be better off w/ a hx30...or a hy35 w/ a 9cm housing...although its goona take a bit to spool it</TD></TR></TABLE>
the compressor is between a 30 and 35. the turbine is the problem. most are 12 or 14cm and there is very few h1c's with smaller housings than that.
a properly built split mani will help spool tremdously, close to 500rpm
Re: (RACINTWEEK)
The regular h1c's had 18-21 cm^2 housings which will be wayyyy to big for you. The only one that might work is the Wh1c which has a 12 cm^2 housing. And this one will still be big for a d-series engine. I emailed you, check it out. I would go with the hx30 if I were u. GL.
something different
1 Post
thanks for the reply and email man..... i think i'm going to look for a hx30 , it seems that would be best.
any input as to what the best way to build the manifold for the split housing would be? what cylinders to pair together.
youd wanna do a split scrool hosing if done properly...2&3 and 4&1 would be the pairings....but my hx35 spools really weel eq pressure w/ the standard 4-1 collector....
the hx30 w/ a small turbine housing would be your best bet...the reason why there isnt any info on the h1c...well because its a pre-decessor to the hx35...and is less effiecent...even the hx30 is gonna be a big turbo...but im assuming you wanna make some decent #'s.....also youll want to run it around 10psi or greater..holsets love hi-boost...and if your lookin for hx30's....a bunch of lull's (contruction fork lifts) have them.
