HKS SSQV utility of the adjustement screw ???
like my topic say ... I dont know the utility of this screw.... I realized that the valve close faster or slower I think.... Why ??? lol
Re: (yellowturbo)
i would like to know this too. i have played with that screw a lot and it has done nothng that i cna ell. no change in the sound and no change in teh way it sounds lol.
Re: (nextelbuddy)
First you should know that the usual tight/loose rules do not apply here.
The adjustment only affects the outside black valve, not the inside purple valve.
No matter how loose you adjust the bov, it will not leak. However, if you adjust it too loose, the parts inside will come apart and possibly jam the bov.
For most applications you want the loosest setting, which allows the bigger valve to open faster losing all of the compressed air
If you adjust the bov more tight, the air will only come out of the small valve first, then the larger valve, depending on the tension. This will create a louder high pitched sound for the small valve, and a smaller deep pitched sound for the large valve. Some people like the bov tightened all the way for maximum "shreek" upon release.
You need a 10mm wrench to adjust. Loosen the nut closest to the bov slightly. Now you can adjust the top bolt to your liking. Go for a drive. Once the bolt is where you like it, turn the nut to the right to "lock" that position. Do not over tighten the bottom nut. Again, be careful not to over-loosen the top bolt. If you loosen it too much, it will come right out.
