highest WHP, pump gas h22
looking for some #'s and dynos if possible,
im making 380whp right now and want to make more on pump but would like to know maxium whp ever known for an h22 on pump and to see different setups for different ideas.
Re: (Turbo Toyz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Toyz »</TD></TR><TR><TD CLASS="quote">i know some one that made 500whp in a h22 with 91 octane.
this was a stock usdm motor.</TD></TR></TABLE>
500whp on a 10:1 motor on 91 octane? I call bullshit to the 10th power
Re: (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote"> give me a couple more weeks </TD></TR></TABLE>
well this guy is building his motor right now, just like you. and it should be done around the same time. i wish there was some way to set up a race between you guys, but Cali to Ohio is a mission.
Re: (Turbo Toyz)
well this guy is building his motor right now, just like you. and it should be done around the same time. i wish there was some way to set up a race between you guys, but Cali to Ohio is a mission.</TD></TR></TABLE>
ii changed my mind i'm keeping my mouth shut
Re: (Turbo Toyz)
so how do you know if someone made 500whp with 91octane.
if the motor isnt even done yet.
Re: (komat)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by komat »</TD></TR><TR><TD CLASS="quote">
if the motor isnt even done yet.</TD></TR></TABLE>
hes being a smartass because i used the "wait till my cars done" kind of thing. Even though i'm only waiting on a v-band clamp and a couple misc. fueland water line fittings.
Re: (komat)
well you misunderstood me. the 500whp was on 91 octane.
the motor blew shortly after now hes building one for 700whp.
Re: (Turbo Toyz)
the motor blew shortly after now hes building one for 700whp.</TD></TR></TABLE>
700whp on 91 octane right? Tell him to use 89 octane, it weighs less
Re: (b16hybridsol)
700whp on 91 octane right? Tell him to use 89 octane, it weighs less </TD></TR></TABLE>
lol
lol
Re: (jdmboostfed)
Pump really varies, as you know, in different states. Only made 308 @ 10 psi on pump. have made 429 whp @ 17 on 113 octane. GT30, 10:1 Arias. S300, etc.
Any specs? Torque? RPM range?
Re: (purpleh22)
I hit around 400 on pump safely sometime last year with the h23a. I had a little bit of breakup so I threw in some 110 and it cleared it up. I stopped at around 450whp. The h series engines are known to have a lower msbc than the b series... so making a lot of power on pump gas with them can sometimes be finicky.
I have tuned a lot of h series engines and they seem to be hit or miss with them making x amount of power on pump. I will typically run 110oct or more after 400whp on the majority of h series i do. B series engines are another story... I've managed to pull 557whp on a b16 w pump. These engines are all fully built by the way.
So to answer your question, add some more boost and see how the engine does. The tuner should be able to distinguish if you run into any problems related to pump gas or not.
Shooting Star
Re: (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote">700whp on 91 octane right? Tell him to use 89 octane, it weighs less </TD></TR></TABLE> haha you stole that from me!!!!
Re: (vtecspeed1320)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecspeed1320 »</TD></TR><TR><TD CLASS="quote"> haha you stole that from me!!!!</TD></TR></TABLE>
i had to
i had to
Shooting Star
Re: (b16hybridsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16hybridsol »</TD></TR><TR><TD CLASS="quote">i had to </TD></TR></TABLE>
I sure hope no one thinks thats serious.
https://honda-tech.com/zerothre...ge=11
well since you dont belive it, here it is.
in the last page you can see how one-fab says he hit 550whp.
Re: (90 integra)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90 integra »</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zerothre...ge=11
in the last page you can see how one-fab says he hit 550whp.</TD></TR></TABLE>
i'm doubting the fact that its being done on pump gas. and one fab was most def on race gas for that power
Re: (90 integra)
Nobody doubted it. By the way, that was a stock h22 and it did not run pump gas. I saw matt run last year out at rockingham with that setup when he broke a retainer. If anyone hit 700whp with a h22 with 91 or 93 octane I can guarantee you the engine didn't last long.
Re: (b16hybridsol)
hey b16hybrid_slow
i never said he made 700whp on 91 octane, i stated that he made 500whp.
so u can stop your hating and stop the stupid jokes that you couldn't even make up on your own. 500whp on a H22 is NOT the most amazing thing ever. just because you alreadly fell that your h22 setup will fail and hardly make any power doesnt mean that this guy didn't alreadly make 500whp. and btw the 500whp that WAS done on the 91 octane did blow shortly after but not before proving that this can be done with a stock h22 bottom end.
hey b16hybrid_slow
Re: (Turbo Toyz)
hey b16hybrid_slow
so u can stop your hating and stop the stupid jokes that you couldn't even make up on your own. 500whp on a H22 is NOT the most amazing thing ever. just because you alreadly fell that your h22 setup will fail and hardly make any power doesnt mean that this guy didn't alreadly make 500whp. and btw the 500whp that WAS done on the 91 octane did blow shortly after but not before proving that this can be done with a stock h22 bottom end. </TD></TR></TABLE>
obviously the bottom end failed for a reason, a stock h22, 10:1 compression + 91oct pushing that much power is prone for detination.
Yes 15.2@89 is slow on my bone stock sol. No my setup has not failed because it hasn;t ran with all the new parts. i'm just being realistic about my goals.. if it makes more, cool.
Being totally honest about this, high compression is not the way to make lost of hp on pump gas. Take it however you want but its a fact. Unless you use something as a detination inhibitor such as meth injection.. but then it wouldn't be a true straight pump gas setup
hey b16hybrid_slow
Re: (b16hybridsol)
heres my setup
built h22 bottom end 9:1 comp.
60 trim turbo (t3/t4)
msd 6a
msd blaster ss
stock cams intake -3, exhaust 0
str 570 gears,
stock head,
rc 750 cc injectors
3in cat back w/ test pipe
2.25in DP
nepTUNE running 19 degrees total timing
18psi, pump gas
tuned by jeff evans
msd 6a
msd blaster ss
str 570 gears,
stock head,
rc 750 cc injectors
2.25in DP
18psi, pump gas
tuned by jeff evans
