Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   HIGH OCTANE (https://honda-tech.com/forums/forced-induction-16/high-octane-763032/)
FullBoostAhead Feb 10, 2004 12:38 PM
HIGH OCTANE
i understand higher octane allows for more boost because it burns slower right? so if i'm boosting 8 or 9 psi, when i go to the track can i boost 12 or maybe more with the higher octane? would this be more stress on my stock bottom end? or will it be the same as the 8 it's just that the higher octance supports it? will this work and how far could i boost using high octane fuel? also how much am i looking to spend per gallon?
Kataku2K3 Feb 10, 2004 01:51 PM
Re: HIGH OCTANE (FullBoostAhead)
You've got the basic understanding... Octane resists burn, this helps prevent preignition and the like... 12lbs. of boost will increase cylinder pressure which in turn creates more power... I don't know what your setup is but it all in the end will rely on what is all done and the tuning... There's no set limit for how much you can boost on any grade of fuel or internal mods done... Typically with completely stock motors we'll run up to ~9lbs... With say pistons and rods 12-14lbs... Sleeved fully built motors 30lbs.+... Again these are just very general number, if you're only tuned to 9lbs right now, don't crank it up unless you're already tuned or planning on getting tuned higher... As for race gas, it'll probably range from ~$5-15 a gallon... Ours runs us about $8.00/gallon for the VP110 we run the Civic's... The VPNOS that Ralph runs in his Supra is ~$10.00/gallon at cost...
