high mileage turbo b18c1 question
i have a 94 gsr stock.
it have 210 miles on the car.
i heard from lots of people it is not a good idea to turbo it.
well, so please give me opinion. should i just go for ALL MOTOR instead.
(but all motor is so damn exspensive)
plus i like turbo more, but i want to keep my AC unit
if i still going to go for turbo.
what do i need to rebuild the motor to be able to handle turbo.
i think boosting 7-8 psi is good enough for me.
the car is going to be my daily and autocross and tracking car.
Re: high mileage turbo b18c1 question (drewsointoyou)
do a compression and leakdown test. If you have no oil leaks and she runs good you will be fine. Just get a good tune and do regular maintenance and your motor should last. I would also recommend to do all major maintenance,(water pump, oil pump, timing belt. ect)
Re: high mileage turbo b18c1 question (D 2da A9)
my thoughts exactly... if its your motor running strong right now....after your maintaniance your set...stock form with a good conservative tune and moderate kit should yield some good power for your daily driver....pistons and rods and new bearings would make it last twice as long
Re: high mileage turbo b18c1 question (JDM_Risa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM_Risa »</TD></TR><TR><TD CLASS="quote">my thoughts exactly... if its your motor running strong right now....after your maintaniance your set...stock form with a good conservative tune and moderate kit should yield some good power for your daily driver....pistons and rods and new bearings would make it last twice as long</TD></TR></TABLE>
well, pistons and rods and new bearing would cost me more then $1000 including install ? how about upgrade them ??
i also heard i should keep stock cams and so on. if i want to go for turbo.
im scared off im gonna blew my motor if i turbo it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 »</TD></TR><TR><TD CLASS="quote">do a compression and leakdown test. If you have no oil leaks and she runs good you will be fine. Just get a good tune and do regular maintenance and your motor should last. I would also recommend to do all major maintenance,(water pump, oil pump, timing belt. ect)</TD></TR></TABLE>
i have also change all those water pump , timin belt and so on.
yeah check everything out and if its all good then i say do it.
i have a high mileage stock b18c1 running 13psi on a sc61. its been fine since fall '05.
