High idle after turbo in a 00 SI
I have a Greddy Kit and after i got i tuned i thought the idle might settle and it idles at around 1500 when fully warmed up and its not over heating and i tried the idle screw and ideas thanx guys
Re: High idle after turbo in a 00 SI (Everyones Hero)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Everyones Hero »</TD></TR><TR><TD CLASS="quote">Sounds like a vacuum leak to me.</TD></TR></TABLE>
Re: High idle after turbo in a 00 SI (SlowB16si)
Yeah i had it tuned on crome and when i went to get it tuned i forgot my air temp sensor so the guy put a little chip in the air temp sensor the fool the computer and it idled around 800 after the tune when i got home and plugge the air temp sensor in it idled at 2000 to warm up the 1500 once warmed up
Re: High idle after turbo in a 00 SI (Themouse)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Themouse »</TD></TR><TR><TD CLASS="quote">Yeah i had it tuned on crome and when i went to get it tuned i forgot my air temp sensor so the guy put a little chip in the air temp sensor the fool the computer and it idled around 800 after the tune when i got home and plugge the air temp sensor in it idled at 2000 to warm up the 1500 once warmed up </TD></TR></TABLE>
Your tuner is a moron.
How do you forget your IAT sensor? Did you cut it off when you installed the kit? The kit should have a place for you to put it in. If not just let it dangle near the intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by F20Cteg »</TD></TR><TR><TD CLASS="quote">
x2
Just plug your laptop in and mess with the idle yourself. It's not hard to figure out.
x2
Re: High idle after turbo in a 00 SI (blaze the chemi)
yeah the air temp sensor was just dangeling there and there wasn't a hole so i drilled one to put it in and then it started to idle high before that it was fine, it wasn't the tuners fault i just forgot to bring it with me because i'm a retart and always forget something but any ideas
