High Horsepower H-series thread
#876
Re: High Horsepower H-series thread
Here's my setup. This is my first H build. I assembled everything myself from oilpan to valve cover. I'm a college student so the build has taken a lot longer, but it coming along.
THE SETUP:
Chassis:
1992 Honda Accord EX
Block:
-97 H22A4 Golden eagle sleeved block (87.5mm)
-Arias 9:0 pistons
-Eagle H beam rods
-ARP main studs
-ACL bearings
-KS balance shaft removal kit
-H23 manual tensionor
Head:
-H22 head
-ARP Head Studs
-Crower Springs & Retainers
-Type S cams
-AEM cam gears
-Stock valves
-Stock IM with butterfly plates removed
-Onmi power 70mm Throttle body
-AEM fuel rail & regulator
Tranmission:
-H23 M2S4 tranny
-8 lbs Fidenza Flywheel
-Stage 5 Competition Clutch
Turbo:
Turbonetics 60 trim .70Exaust
-LoveFab Mini me Manifold
-HKS blow off valve
-TIAL 38mm wastegate(10Lbs Spring)
-Omni power 3bar map
-AEM WideBand
The build has just been finished I'm working out all the kinks now. Once everthing is complete.. Then I'm off to the dyno!
I really don't know what to expect from this setup, but I hope it puts down good numbers. Any suggestions would be great!
THE SETUP:
Chassis:
Block:
-Arias 9:0 pistons
-Eagle H beam rods
-ARP main studs
-ACL bearings
Head:
-H22 head
-ARP Head Studs
-Type S cams
-AEM cam gears
-Stock valves
Tranmission:
-H23 M2S4 tranny
Turbo:
-HKS blow off valve
-AEM WideBand
#878
821whp raced ten years on the stock gear set,from 400-800 but its in a stripped down hatch extralargenog brakes gear sets like crazy in his accord,more weight more break
#879
OEM gearset in a Hatch has a CHANCE of lasting a minute at 600ish, for a minute, after that... TICK TICK TICK...
Add a fat chassis, and BOOM sooner. Hatchbone: When did you redyno and make the 821 ?
Just ordered another forged straightcut set Monday for another guy here... May have toom for one more, but PM me so Mods dont get pissed.
#880
Right before i fried all my valves lol sad thing is the car is stripped right now on to try this rwd thing out ,you need a twin disk Holland at me I got one for dirt cheap
#882
Just a little something to think about when you all are putting your set ups together...
New: H2K Intake Manifold Adapter and K2B Throttle Body Adapter
#883
I live under a rock
Been whittling away at this, going to Ben Freed @Freed Engineering early next month for the piping and other misc fab. Going to have to get creative with the intercooler mounting and radiator mounting.
This is the, I don't know really...... 7th turbo setup this thing has had? Started with a rev hard kit back in 2000. Been a long expensive, frustrating road. Lol.
#885
My New Set up!
Bottom End
GE Sleeved & O-ringed
CP Pistons 9.0 CR
Eagle Rods
ACL Race Bearings
KS Balance Shaft Kit
Head
Skunk 2 Pro 1 Cams
Skunk 2 Cam Gears
Full Ferrea Valvetrain
3 Angle Valve Job
GE Intake Manifold
74mm Skunk 2 TB
Fuel
ID 2000cc injectors
Twin Bosch 044 Surge (in bay)
255 Wal. Pump (in tank)
AEM Fuel Rail & Regulator
Trans
Syncrotech P2A5 (accord trans)
MFactory LSD
Syncrotech Full Carbon Syncros
Competition Clutch Twin Disk
Engine Management
AEM Series 2 EMS
Turbo Set up
Precision 6262 BB Turbo
Tial MVR 44mm Gate
Tial 50mm BOV
Full Race Backdoor Intercooler
PeakBoost Ramhorn Manifold
Next Step, Straight cut gear set!
All this on a 1993 DA Integra (lol who would've thought!)
Bottom End
CP Pistons 9.0 CR
Eagle Rods
ACL Race Bearings
Head
Skunk 2 Pro 1 Cams
Skunk 2 Cam Gears
3 Angle Valve Job
GE Intake Manifold
74mm Skunk 2 TB
Fuel
ID 2000cc injectors
Trans
MFactory LSD
Engine Management
AEM Series 2 EMS
Turbo Set up
Tial MVR 44mm Gate
Tial 50mm BOV
#886
I live under a rock
All the covers are there, just "mooned" around the valve cover and lower plastic cover. But the rear cover is there, chance of something falling in pretty unlikely.
Tubby- I don't know if that walbro can feed 2 044's from the tank to a surge like that. Never seen it done anyway. What size lines? And are you against sumps? I don't want to sump because I don't have the time/money to race competitively and would rather just have a nasty street car I can play around with. Just curious. I suppose you could replace the 255 with one of the new 450's if need be
#888
A wally as a 'lift pump' to a surge tank with a pair of 044's works pretty well, that is how mine is setup... although on an F22 sohc. E98, ID2000's, 6265 etc... and supporting plenty of power thus far.
#891
Good to see you car closer to done (again) Spoolin! I like the idea of the Walbro feeding 2 044's, in a small tank, that's what I am planning for when I go boost.
#892
I live under a rock
I've seen the surge tank approach many times, just wasn't sure of the walbro's ability.
Surge tanks are all the rage in Europe. Practically everything fast over there has a surge setup in the trunk.
I may switch to ID2000's from the 1k's and add another 044 in parallel. I have the 255 pump feeding my single 044 inline at the moment with -10 lines. I have pretty easy access to E-85 I just don't know if I want to spend the money on the pump and injectors. I'm going to get it up and running as it as, and see how it does. I need to have a running car before I change ****, I've been famous for that for years now.... need to stop.
Thanks Man, I'm glad it is too.....
#893
If you have any intention of running on E-85, I would say the ID 2000s will be a must. And either dual 044s or a big Weldon pump. Of course I am going on the assumption that you plan to push that turbo into the 30+ psi range and need that much fuel.
#894
Skunk2 makes a adapter plate for a K2B because a K-series intake is better right? Suppously better than their old manifold. How come skunk2 just doesnt remake the H seires manifold the way it should be instead of this adapter plate nonsense?
#895
They probably figure they can probably sell more adapters for proven OEM intake styles than their own intakes. That and some of their intakes kind of suck.
#896
Old topic, but maybe some of you will be interested.
We've launched an Indiegogo campaign in hopes of the H-Series community coming together to make the product happen.
Indiegogo Campaign: H22A Ultra Race Intake Manifold - Skunk2 Racing
