high egt temp!!!!! 1725-1750F
today when i was getting on it and in 4th gear my EGT temps went up to about 1725-1750 (950C) and i hurry up let off... anyone know what kind of damage this will do to the motor if it already didnt do any damage? i am tuned on a hondata 2b and the car been running weird lately and normally it doesnt go past 1600-1650... i know i should get it retuned soon after i change out a few parts... do anyone have anything to say about this? i'm just kinda worried about this, egt probe is about 1 inch away from the 3rd runner. running 10 lbs of boost
ls vtec w/ b16 head
81.5mm 9:1 endyn rw
eagle rods
720cc injector
aem fuel rail
sx fpr
hondata 2b w/boost
turbonetics t3/t4 ar63 .57 trim
greddy r bov
drag manifold
itr intake manifold
spearco intercooler 26x8x3
jg tb
crane ignition w/ external coil
hks 40mm wastegate
2.5 down pipe
thermal 3in exhaust no cat
ls vtec w/ b16 head
81.5mm 9:1 endyn rw
eagle rods
720cc injector
aem fuel rail
sx fpr
hondata 2b w/boost
greddy r bov
drag manifold
itr intake manifold
jg tb
hks 40mm wastegate
2.5 down pipe
Re: high egt temp!!!!! 1725-1750F (tRaCeBuStAbUsTeR)
is that setup tuned? you might need to add more fuel or advance the timing in that RPM range ro keep the EGT's down.
Re: high egt temp!!!!! 1725-1750F (Muckman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Muckman »</TD></TR><TR><TD CLASS="quote">...Or less fuel or retard the timing. High EGTs can result from either extreme. Basically a symptom that its out of tune.
Take it back to the tuner.</TD></TR></TABLE>
Re: high egt temp!!!!! 1725-1750F (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC »</TD></TR><TR><TD CLASS="quote">is that setup tuned? you might need to add more fuel or advance the timing in that RPM range ro keep the EGT's down.
out of curiosity, how does advancing the timing reduce the temp
Re: high egt temp!!!!! 1725-1750F (Mad Chemist)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mad Chemist »</TD></TR><TR><TD CLASS="quote">
out of curiosity, how does advancing the timing reduce the temp</TD></TR></TABLE>
he probably meant reduce
advancing the timing can also help with egts cause there may be some fuel that is not being burned fully in the combustion chamber. thus resuslting in it burning in the exhaust wich raises egt's.
1700 is high, but ive seen higher, it needs some attention but dont forget that your in fourth and that, although not like 5th, is higher strain on the motor. especially if your going up a hill.
Landon
Landon
Re: high egt temp!!!!! 1725-1750F (boosted_dc2)
is there anything like a guage or something that i can get to monitor my air fuel ratio? i dont want the light show, i want something that works good... im running hondata 2b, datalog???? how???
Advancing timing fires the spark plug earlier, and combustion finishes earlier, so the exhaust has more time to cool before coming out the exhaust valves. Advanced timing = cooler EGTs. It does not mean that the temps in the combustion chamber are cooler, however.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR »</TD></TR><TR><TD CLASS="quote">is there anything like a guage or something that i can get to monitor my air fuel ratio? i dont want the light show, i want something that works good... im running hondata 2b, datalog???? how???</TD></TR></TABLE>
Get a wideband. I like the PLX M300.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR »</TD></TR><TR><TD CLASS="quote">how much does it cost and is it a standalone unit?</TD></TR></TABLE>
http://www.plxdevices.com/
BoOsTiN Dc2
04-24-2004 07:18 PM
