High Altitude Tuning and other stuff
Old 10-27-2013, 09:58 PM
MrBlaaaaah's Avatar
Default High Altitude Tuning and other stuff
So, I have begun the design stages for a race car for the Pikes Peak International Hill Climb. Being half way through my frame design, I needed to chose a motor. Upon deciding on the Honda B16 or B18 block, with a turbo setup, I slowly come to the conclusion that I don't know that much about tuning for high altitude. That is, 9,000 to 14,000 feet. So, I extend a question to anyone here.
What do you do differently when you tune for a higher altitude? Even if it's for 3,000 feet instead of sea level, or 6,000 feet instead of sea level.
The other stuff probably fits better in a different sub forum, so nevermind on that.
Old 10-27-2013, 10:50 PM
Who is Mr Robot?
wantboost's Avatar
Default Re: High Altitude Tuning and other stuff
Any good EMS with barometric compensation will be able to take the tune to any altitude, provided it was tuned properly in the first place
Old 10-29-2013, 01:43 PM
Dark_Teg's Avatar
Our Hondas use a speed density system that does not compensate for altitude. I was running a perfect 14.7 @ idle in Dallas and a 14.1 @ idle in Odessa. The corrected altitude is easily 3800ft apart. Tune it for sea level and just run a little rich at altitude is what I would do.
Old 10-29-2013, 07:51 PM
Who is Mr Robot?
wantboost's Avatar
stock ecu based tuning, this is true
things like the aem have baro correction
Old 10-29-2013, 07:55 PM
Turbo-LS's Avatar
Building a pikes peak car should be looking at motec and nothing else.
want2na
05-23-2017 10:00 AM
Asbill572
02-25-2013 06:55 AM
playahwitgame
07-05-2006 05:20 PM
turbotime
05-09-2005 01:00 PM
Quick Reply: High Altitude Tuning and other stuff
