Hesitation, Sputter or Mis-Fire? (not 56k friendly)
Finally finished everything up lastnight . . . . I was driving around bumperless for a couple days since we were having piping clearance issues, and I was not boosting. I bolted on the flange for my downpipe to cover up the hole on the back of my turbo that was put there to convert it back to internal wastegate . . . . . after that I was making boost like no tomorrow.
* I gota say that t3/t4 turbos are hellah loud even while cruising * anyways as I was leaving a stoplight I gave it just a little gas nothing crazy and it kinda felt like it was either hesitaiting, or like it maybe mis-fired, so I turned around and went to put gas in my car thinking that maybe I was a little low, but turns out I still had like 3 gallons.
I am getting my downpipe made tomorrow and i'm trying not to drive my car much since I can't plug my o2 sensor in since there is no spot for it yet. I just made sure to turn the fuel up a little before I unplugged it and was running all motor to be sure I would run some what rich.
I did however get 2 step colder plugs, I just did not re-gap them, could that be why I kinda felt that little hesitation or mis-fire? I even felt it once on the highway at about 4500 rpms . . . .
any help is appreciated
here's some pics
here's some pics
Re: Hesitation, Sputter or Mis-Fire? (Vtec92Civic)
Well it could be a number of things...
any CEL's?
sounds like it might be running a lil rich but what FMU are u running???
neeed more info
any CEL's?
neeed more info
Re: Hesitation, Sputter or Mis-Fire? (PRojectSi2)
right now no CEL Lights at all . . . current setup:
Drag Manifold
VAFC
DSM 450 Injectors
Walboro 255lph Fuel Pump
Turbonetics T3/T4 Turbo .63 a/r
Tial 35mm Wastegate
Greddy Type S BOV
*my o2 sensor is currently not plugged in ebcause there is no spot for it, but tomorrow my down pipe is being made, so I should have that squared away then*
I before I took off my headers and had my car N/A I did up the fuel a little to make sure that I was running a little more on the rich side so that I would be ok to drive it to get my exhaust work done, and since I was not going to have my o2 sensor plugged in I wanted to make sure I had more then enough fuel.
I believe I got my settings on the vafc starting at like -33 and I wind up with like -31 in the high rpms . . . that might be a little rich. I have not pulled the plugs to check it, and I remember my last setup running to rich did lead to some hesitation.
Could it be that my spark plugs are not gapped properly though?
Drag Manifold
VAFC
DSM 450 Injectors
Tial 35mm Wastegate
Greddy Type S BOV
Re: Hesitation, Sputter or Mis-Fire? (project dc2)
QUOTE=project dc2]gap the plugs at 28. and put that o2 sensor back in and youll feel a big difference. [/QUOTE]
Thanks Philip
I been meaning to ask . . . what exactly does gapping the plugs do . . . beter spark? smoother idle?
what would be the difference between say gapping them at:
.40 as appose to .28?
I kinda thought it was the gaps on my plugs because my last setup I had them gapped at like .30 or .32 and this time I neevr gapped them at all.
I also keep getting a code 43 (fuel system) but my guess is possibly the o2 sensor not being able tor ead the exhaust is what might be causing that code.
Thanks Philip
EK9 BEEZLER
01-14-2006 01:38 PM
