How to uninstall the black box
OK i'm trying to complete the afc hack on my d16z6 turbo cx but i don't know how to uninstall the greddy black box? any help would be appreciated
also what is the difference between the black and the blue box?
thanks
thanks
Re: How to uninstall the black box (KoRE)
The box is only spliced in to the ecu, just cut the wires that are spliced off to the box and connect the map sensor wire back together.
and make sure you don't have any open or exposed wires.
[Modified by Trac226, 5:57 PM 6/27/2002]
Re: How to uninstall the black box (Trac226)
there is one wire that runs into the ecu. the others are on the iat (intake air temperature sensor), map sensor, and the coolant sensor. just cut the wires and sauder the original wires back to their origin. it's that easy and you'll notice the dump in fuel.
i think you guys are talking about the blue box i just uninstalled it it was easier then i thoguht so it's uninstalled
and the afc hack is working perfect just for an idle problem which was there b4
Maverick77
11-12-2002 02:13 PM
pelotudo
08-30-2002 06:45 AM
