Help With Oil Supply Line for a T3
Old 01-23-2006, 06:44 PM
brixity's Avatar
Default Help With Oil Supply Line for a T3
Just bought a turbo from westcoastturbo and the turbos supply line is just a hole. It doesn't have any threads to put a fitting in there. It kinda looks like the return side with the 2 spots for the screws and a flange but but instead of the big square for the return there is a small hole but no threading to put a fitting in. Any body else have this problem or ran into a similar problem that can help.
just found this flange on ebay... is this the flange i need for the oil supply?
http://cgi.ebay.com/ebaymotors...QrdZ1
Old 01-23-2006, 07:01 PM
D-t
D-t's Avatar
Default Re: Help With Oil Supply Line for a T3 (brixity)
Yes! You need a feed/return line kit for your setup. That should work. ATP, fast-turbo.com, and stealthmode.com also sell oil line kits.
Old 01-23-2006, 07:27 PM
CRXDrew's Avatar
can you tap the hole? I know some T3's off of Saabs are the same way. You can easily tap it with 1/8 npt
Old 01-23-2006, 08:12 PM
racerxadam's Avatar
Default Re: (CRXDrew)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXDrew &raquo;</TD></TR><TR><TD CLASS="quote">can you tap the hole? I know some T3's off of Saabs are the same way. You can easily tap it with 1/8 npt</TD></TR></TABLE>
if you decide to do this make sure you put grease on the tap to collect any metal shavings and try to do it upside down in a vise so anything the grease doesn't catch will hopefully fall out and not into the center section
Old 01-24-2006, 09:30 AM
brixity's Avatar
i rather not tap it cause i don't want to take any chances messing it up.
Old 01-24-2006, 09:45 AM
R6E6I6D's Avatar
Default Re: (brixity)
tapping it would in all honesty be the best way...
like they said slap some grease on the tap
if not you will need to get and oil line kit make sure that when u get the kit it comes with gaskets for that flange
hangac1093
10-27-2006 06:23 PM
97turboteg
04-02-2006 09:42 PM
RNPoo7
08-05-2005 06:44 PM
the.hamburglar
08-02-2005 01:07 PM
importboi22
10-04-2004 05:45 PM
Quick Reply: Help With Oil Supply Line for a T3
