Help with oil pressure sensor removal!
I'm putting a revhard kit on my 94 integra LS.. so far things have been going relatively smoothly up until this. My question is, how the hell do you remove this? I've tried 22mm, 23mm, 24mm, and even a 15/16" socket.. none of which will fit around it. There isn't enough clearance to stick a set of pliers on either. Does anyone have any helpful tips or information? thanks
Re: Help with oil pressure sensor removal! (harrytg)
it's hard but FOR SURE 15/16 or 24mm socket works
BUT you gotta get deep socket... the shallows too small
also, try using a 15/16 wrench FIRST then socket it out.. or just a adjustable crescent wrench... it's not on tight.. only 8.7ft-lbs
Re: Help with oil pressure sensor removal! (hatch808)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch808 »</TD></TR><TR><TD CLASS="quote">you can go to auto zone and they have a oil sensor socket for like 3.99</TD></TR></TABLE>
hahah.. wish I had known this
after spending 40-50 dollars in sockets, I finally found that 27mm fits. very odd indeed.
thanks for the tips guys
yeah its a bitch i used an adjustable wrench sensor seems too soft and it kept slipping just takes patience.
RACEPAK
17
05-19-2005 04:53 AM
sohc_vtec 2NR
03-04-2004 09:48 PM
