Help me diagnose my oil burning problem..
Ok things i did:
Compression and leakdown---175 across and less than 4% across. Basically telling me that its not rings, a head gasket, or warped/cracked head.
Replaced PCV.
Pulled intake and downpipe from both sides of turbo--no oil found.
Pulled charge piping at tb--no oil found.
It burns oil only after warm-up (hot oil=thinner oil) and smokes a good amount after high RPM decleration or when clutch is down and cd\ar is put on neutral to coast.
Ok, I am thinking its the valve seals. Anyone else care to help me?
By the way, the smoke is coming through the exhaust--not oil dripping onto hot exhaust.
Replaced PCV.
EG6_LS_BOOST
03-18-2014 05:49 AM
