Help me determine cond of my spark pugs? SOHC-T
I was wondering if someone can help me determine if my saprk plugs are good or I might running to hot?
CYL 1 2 3 4
CYL 1 2
CYL 3 4
CYL 1 2 3 4
CYL 1 2
CYL 3 4
Re: Help me determine cond of my spark pugs? SOHC-T (11psiTurboSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 11psiTurboSI »</TD></TR><TR><TD CLASS="quote">Looks like your running rich</TD></TR></TABLE>
What makes say that?
Re: Help me determine cond of my spark pugs? SOHC-T (booscivic)
yeah turbo cars should be a little on on black side cause they should run a little rich those look a little lean if anything, but not much
Re: Help me determine cond of my spark pugs? SOHC-T (Hyaboosta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hyaboosta »</TD></TR><TR><TD CLASS="quote">yeah turbo cars should be a little on on black side cause they should run a little rich those look a little lean if anything, but not much</TD></TR></TABLE>
I need explanation what are they suppose to look like becasue now Im confused
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">I need explanation what are they suppose to look like becasue now Im confused</TD></TR></TABLE>
black means u are running rich....whitey..usually mean you're running lean.
so..you kinda want to be in between
Re: (Hyaboosta)
The plugs been in the car for too long not sure but guessing more than 7 months. Im also using alcohol injection trying to tune it right now.
Re: (booscivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic »</TD></TR><TR><TD CLASS="quote">The plugs been in the car for too long not sure but guessing more than 7 months. Im also using alcohol injection trying to tune it right now.</TD></TR></TABLE>
looking at your plugs to tune a car is not the correct way to go about it.
Shoudn't a well running turbo setup have a plug that looks like a toasty marshmallow, although a little burnt because of the richness?
Re: (flood)
The car been tuned already, I added the alcohol injection so you have to set it when you wanted to turn on, too early and quenches combustion.
