Help Everybody, Have Problem with my Turbo Setup, Need Everybody's Help
Hello, I'm running a:
1994 Honda Civic Si
Engine D16Z6 1.6L SOHC VTEC 92-95 Civic EX/Si 125hp
Garret Turbo T3/T04E Ballbearing
J.E Pistons & Rings
Conrods by Crower
Turbo Exaust Manifold by SSAutoChrome
3 Bar Map Unit
Light Flywheel
Clutch by Clutchmasters
720 CC Injectors with Resistor
Walbro Fuel Pump for 7 Bar
Webber Fuel Pressure-Adjustment PR1/3B
Front Big Intercooler
2.5" Boost Pipes
Greddy Type-S Dump Valve
R1 Cone Air Filter
Greddy Profec B Boost Controller
AEM Independence Programmable ECU
BlockGuard by KMS Engineerings
Bigger Radiator
Accel ThunderStorm 300+ 180mm Ignition Wires
Iridium Spark Plugs
now, my problem is, my turbo i starting to spin like at 4,500 Rpm, giving me 0.5 bar at full wastegate....
at 6000 RPM it gives me 1.2 - 1.3 Bar....
I donno what to, I'm starting to give up, open for any suggestions, Avi.
1994 Honda Civic Si
J.E Pistons & Rings
Conrods by Crower
3 Bar Map Unit
Light Flywheel
2.5" Boost Pipes
R1 Cone Air Filter
Bigger Radiator
Iridium Spark Plugs
Re: Help Everybody, Have Problem with my Turbo Setup, Need Everybody's Help (94gsr4dr)
I got an External Wastegate by SSAutoChrome, but I'm using an Electronic Boost Controller... here's the pic:
http://www.stockreco.com/Wastegate35mm-004.jpg
Re: Help Everybody, Have Problem with my Turbo Setup, Need Everybody's Help (T-Charged-Civic)
I don't know a whole lot about the wastegate, but i am gunna guess that it may be the problem. Their quality isn't known to be the best. Your best bet is to buy a tial. Even if the problem persists atleast you got a better wastegate.
Re: (T-Charged-Civic)
Do you know what spring is in the gate? If you blocked off the wastegate hole and get the same reading you do when the wastegate is on then the wastegate is not opening at all. I hope I am reading your post correctly, it is kinda confusing. I would double check to see what spring you have.
-Ryan
-Ryan
