Help with D series turbo, new to turbos.
I have a Eg Hatch DX. I am debating between turboing a d series or swapping in a b16 SiR-II
If I trubo the D, should I buy a "new" one from Hmotorsonline they are dirt cheap and have around 35K on them.
Realistically how much does a turbo setup run for a d series inc. all misc parts.
ANy sites you guys cna recommend to me so I can research this further, I tried a search but came up with nothing but for sale or WTB info
Any help is appreciated.
Re: Help with D series turbo, new to turbos. (kwik2nec)
I would only piece together a kit if you really did your homework about whats involved with building a turbo kit, or how turbos work.
Depending on your budget, you can pick what kit you would like, or whether you look for a used one or not. If you are looking to go over 10psi of boost, look into a kit, or expect to get engine management that can adjust engine timing. Not all kits come with timing control.
Re: Help with D series turbo, new to turbos. (KarbinFourteen)
Yeah, If not faster.
If you get a good turbo set-up and tune it decently you should be able to make more hp and more tq then a sir2. i've seen a lotof urbo d's runing 160-180whp and about 150lbs of tq.
compare that to a stock b16 140whp (+/- a little) and about 100lbs of tq.
Re: Help with D series turbo, new to turbos. (b16ahybrid)
How do you tune it properly, what PSi do I use (is this the smae thing as boost). Sorry for new questions but I gotta start somewhere to learn. Any decent turbo sites?
Price wise is it more cost effective to turbo?
Also the b16 Si-R ii is a jdm motor that puts out 170 hp and 113 tq
http://www.hmotorsonline.com/s...30005
Well, with 7psi of boost, I'm making 178 whp, which is about 210-215 at the flywheel. Its also easy to turn up the boost to 10 psi or so for racing and have about 240 hp, or close to 200-210 whp.
Kits, like the Edelbrock and Greddy come with fuel management. For 7psi + on the Greddy, you would need a intercooler, otherwise you'll run into detonation issues as the weather gets hotter, and a BOV (blow off valve) to increase turbo life.
http://www.turbod16.com Plenty of resources on turbocharging d-series engines. Read thru the FAQ forum.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KarbinFourteen »</TD></TR><TR><TD CLASS="quote">Also the b16 Si-R ii is a jdm motor that puts out 170 hp and 113 tq
ht
tp://www.hmotorsonline.com/s...30005</TD></TR></TABLE>
Yep but thats flywheel hp.
For a decent turbo set-up expect to spend about $2500 for everything. So yeah it's cheaper then doing a swap.
Do some searchingon here about turbo set-ups, you will learn a lot. If you have specific question by all means post them but most generalized questions will be directed to the search function.
http://www.cheapturbo.com has good prices on turbo's.
You can find used intercoolers on here for about $150
maifolds can be found on here for anywhere from $100 used to $600 new (and every price in between).
Fuel management can be found here too.
You can use a fmu,high flow fuel pump, and larger injectors.
larger injectors and hondata.
larger injectors and a v-afc
Other forms of stand-alone (motec,aem,greddy e-manage,etc)
The basics that you will need
Turbo
manifold
intercooler
fuel management
oil feed and return lines
blow off valve
wastegate
intercooler piping
exhaust/ downpipe
Now go search all that stuff to learn more about it
Hope this helps you
ht
Turbo
manifold
intercooler
fuel management
blow off valve
wastegate
intercooler piping
exhaust/ downpipe
Hope this helps you
I say go with the turbo d-series since you already got the motor and then move on to a turbo b-series once you learn if your really interested in it. I spent about $1100 on my turbo kit and all the parts were pretty much new.
n*werk
10-08-2012 09:10 PM
