HELP before I order part for my drag 3 kit :)
Old 01-29-2002, 10:59 PM
intekragsr's Avatar
Default HELP before I order part for my drag 3 kit :)
ok, another problem :*( the brass oil "T" thing wont fit on my block. I read that one post, but it doesnt seem to answer my question. I am figuring I need to order the 1/8" NPT(f) to 1/8" BSPT(M) adapter, but is that the right size for a 2001 gsr? Is there a way to install it without another adapter? Is there any closer places to order it from cuz im in california and I dont want to delay my install that long. Also how much does that cost????
I really appreciate all the input and help you guys have given me THnx
Old 01-29-2002, 11:03 PM
dustin's Avatar
Default Re: HELP before I order part for my drag 3 kit :) (intekragsr)
I got the 1/8" NPT brass tee to fit. But yes 1/8" BSPT is the correct size.
Dustin
Old 01-29-2002, 11:12 PM
intekragsr's Avatar
Default Re: HELP before I order part for my drag 3 kit :) (dustin)
so I only need the 1/8" NPT(f) ? not the 1/8" BSPT(M)?
How much did it cost you dustin?
haha damn you on like 24-7 ......its all good though......thanx for the help.....i would be nowhere in the install if it werent for you. Oh and another question, when you mounted your intercooler, it says to put as close to the radiator as possible, but for my car there is an AC thing sticking out. So I have to mount it infront so there is about 2 inches between my radiator and intercooler. Im not sure if my bumper gonna fit.
sorry another question, how do I tune my hks racing bov? can i just stick it on there and it will be fine? there is no marking on it to tell which way is softer or stiffer. well neway...have you heard it before?
haha i let you go now....thanx
Old 01-30-2002, 12:19 AM
intekragsr's Avatar
ok im confused, do i ask for a 1/8" brass T or 1/8" NPT ????
I need to knoe exactly what it is called so I dont delay myself by ordering the wrong part.
THnax
Old 01-30-2002, 12:25 AM
turbopimp's Avatar
The 1/8 npt tee should work fine...are you sure you're threading the fitting into the block straight? Make sure you dont have any dirt/junk on the threads and it should go in. Sometimes it's difficult to get a straight shot since it's pretty cramped working back there, just be sure not to cross thread no matter which fitting you use, but most turbo Hondas use the 1/8 npt with no probs...
Old 01-30-2002, 12:41 AM
turbopimp's Avatar
On the AC line you can GENTLY bend it so that it's almost flush against the condenser core. This will allow the IC to be mounted further back. Best thing to do is to temporarily install the turbo/man/dp assembly first and clock the compressor housing so that the nozzle is pointed downward and also parallel to the radiator, then run the pipe from the turbo to IC. This way you'll know exactly where to mount the IC so that everything lines up correctly for a clean install...
Old 01-30-2002, 01:23 AM
intekragsr's Avatar
Default Re: HELP before I order part for my drag 3 kit :) (turbopimp)
yea its goin in straight and wont fit at all. i guess dustin had to buy another part too.....i just need to knoe exactly what he ordered.
Old 01-30-2002, 03:37 AM
New User
Erik_Pb_Foot's Avatar
for those of you that knows your ish, do you need the 90 degree piece for the manifold to mount the wastegate.... or will a Tial wastegate fit w/o it under the Integra hood? Thanks
Old 01-30-2002, 02:48 PM
intekragsr's Avatar
Default Re: HELP before I order part for my drag 3 kit :) (Pb_Foot)
no the 90 degree thing is not necessary, the tial fits on mine with no hood clearance probs
turbo2000
07-01-2003 06:15 AM
tygsr
05-08-2002 04:18 PM
CM-R
10-10-2001 11:53 AM
GSRrR
09-15-2001 07:39 PM
hdrcivic
09-04-2001 04:48 PM
Quick Reply: HELP before I order part for my drag 3 kit :)
