Help/advise for b series turbo build
Ok so for starters I have a stock Ls turbo efheres wat I have
Stock Ls motor and trans
2.5 charge pipe and the rest I's 2"
450 dsm injector
Walboro 255 fuel pump
Inline pro cast iron manni with 2.5 dp and exhaust mandereal bent
Drag intercooler
S100 ecu
I made 270whp and 230tq I'm shooting for 300's what would I have to do? In other words a budget build please chime in with diff ideas. My other option was to but another fresh Ls motor do ard head studs and boot it to 300hp and blox intake manni idk lmk wat u guys think I have a kid comin in 2 mnths so can't slurge
450 dsm injector
Drag intercooler
S100 ecu
Re: Help/advise for b series turbo build
Ok thats wat I'm thinken I jus dnt know how reliable I'm getting a jdm long block fir that for 600 good idea or I rarely drive the car
1 Post
450 dsm injector
Drag intercooler
S100 ecu
450 dsm injector
Drag intercooler
S100 ecu
Ok Im gonna buy a blox intake manni should I use stock throttle body or upgrade and as for turbo I have a turbonetics t3t4oe 60 trim
1 Post
Yes it's not 100% needed but it will let you achieve more whp very easily. Not a bad upgrade considering you can pick them up used for $80-100.
I thought the heads breathing was bad so instead of internal work I was gonna atleast put a manni on it
Moderator
More power very easily is acheived with a $80-$100 boost controller.
Ok so basically debating on the I m but wat about 2.5 dp to 2.5 mandereal bent exhaust to bibrant 3" inlet and outlet muffler will that be ok for my goal I know it'll be better to go 3" but this place by me wants a lil over 600 for the set up so. Lmk thanks for all the info and advice h-t
TheShodan is correct. If you want 300 all you need is bigger injectors and turn the boost up. Anything else is wasting money to get you to your goal. Torque may hang in there a little longer with a different manifold but not needed for 300.
Moderator
killablaze
10-07-2005 04:06 PM
