Help, About to Turbo. Help... FPR questions
Old 12-28-2008, 02:17 PM
H4tchster's Avatar
Default Help, About to Turbo. Help... FPR questions
Setup: Stock B16a2 205-210 compression across the board.
Walboro 255 LPH Fuel pump (Installed)
Hondata S200B Stock b16 base map-Untuned
440cc RC injectors or 750cc RC injectors
AEM Fuel Rail.(Installed) w/stock FPR
Inline Pro SS Manifold- Ceramic coated
Precision SC34 Turbo, 63A/R
2.5" Downpipe
2 1/4 Intercooler piping all around (Installed)
27x6.5x3" FMIC (Installed)
Turbonetics couplings and T-bolts Clamps (Installed)
Moroso Oil pan or a GSR oil pan tapped
TunerToys Oil feed Line, and Return lines...
Questions:
I had a Question about if I would need a AFTERMARKET Fuel Pressure regulator for this?
Would I need a Fuel Pressure Gauge to be on the Safe side? Also what type of Fuel Pressure Gauge should I get that goes over the Stock Fuel Filter, and what type of Fitting adapter do I need in order to install it over the fuel filter?
I tried to install my AEM Fuel pressure regulator, and the Fuel Pressure gauge needle went around 1 whole time and the needle stayed under 0.... Im confused...??? I know I installed it right, because there were no leaks...
Everyone is telling me I need a FUEL PRESSURE REGULATOR for my setup??? Im confused... wouldnt my 440cc or 750cc be good enough for this? since I already installed my fuel pump..
Im just trying to get everything answered that I need before I throw on everything, and then Lean out or Rich it out and cause detonation and Blow my Motor, this is my DD so I want to make sure everything is alright..
Anything you might want to help me out with....
All help would be appreciated...
Old 12-28-2008, 02:58 PM
H4tchster's Avatar
Default Re: Help, About to Turbo. Help... FPR questions
Bump. Someone's got to know something about this..
Old 12-28-2008, 03:18 PM
Adriano's Avatar
I would put one in. You have some nice parts on your car, spent the extra $150 and be safe.
Adriano
Old 12-28-2008, 03:54 PM
H4tchster's Avatar
Yeah, But why does my FPR act weird? Its a AEM FPR, but the Gauge always reads under 0 Like it goes around 1 full time and the needle stays under 0psi.. Its a Liquid filled gauge
Old 12-28-2008, 04:48 PM
da_dude's Avatar
You'll be fine with the stock FPR.
Old 12-28-2008, 06:23 PM
H4tchster's Avatar
See thats what I dont get, Some people say get a Aftermarket FPR, and Some say my Stock one is fine...
Please someone will you supply me with the right answer for my Setup?
Old 12-28-2008, 06:58 PM
boostnbee's Avatar
youcan add one if you want but stock will be fine. there are 5 and 600 whp motor hondas running stock fpr's use either you will be fine either way
Old 01-01-2009, 01:09 PM
H4tchster's Avatar
is 1/8NPT equivilent to a -4AN fitting?
Old 01-01-2009, 05:28 PM
extralargenog's Avatar
AEMS are GARBAGE...
If you like your motor, and dont want to blow it the **** up due to an AEM regulator shitting itself..... Go Aeromotive.
Old 01-01-2009, 05:34 PM
streetracer6rpt's Avatar
aeromotive.....
Old 01-01-2009, 05:40 PM
Teglove2's Avatar
I made 550whp w a stock FPR...they work fine...if I wouldve went higher than I wouldve went Weldon or Aeromotive
Old 01-01-2009, 05:50 PM
nonvtecallmotor's Avatar
AEM fpr's are junk. AEM does make a remote fpr that is way nicer then the rail mounted one.
attack666
12-03-2010 06:53 AM
MantisX
05-30-2008 11:53 AM
Quick Reply: Help, About to Turbo. Help... FPR questions
