Help!
OK well I boosted my d series this week and I have a few problems/questions.
#1- When I have my blow off valve all hooked up to the vacuum source it works well and all, but I do not get the nice torque that I do when I cap off the blow off valve,whats this about? and #2-My boost gauge will only read vacuum like way down to 20 in vac and it goes up slowly if I press the brake. I am so frustrated right now I am about ready to rip the whole set-up off my car and get out of boosting. |
Re: Help! (tolowhb)
bump
Re: Help! (tolowhb)
What kind of bov? is it leaking under boost? Can you elaborate on the vacuum problem?
Re: Help! (fab-forum.com)
It is a Turbo xs rfl, I think it must be leaking or something but when I take it off from its vac source and run with no bov I seem to boost fine. Maybe the spring inside is to weak and opening early??? As for the vac problem, I have my boost guage hooked up to a golden eagle vac manifold which is tapped into the brake booster, and it never leaves the vac area it usually stays around 20 in the vac area.
Re: Help! (tolowhb)
Bump
Re: Help! (tolowhb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tolowhb »</TD></TR><TR><TD CLASS="quote">
#2-My boost gauge will only read vacuum like way down to 20 in vac and it goes up slowly if I press the brake. I am so frustrated right now I am about ready to rip the whole set-up off my car and get out of boosting.</TD></TR></TABLE> You wouldn't happen to have it connected to the brake booster would you? http://images.honda-tech.com/set1//smile/emcrook.gif For number #1 your BOV could be leaking. What's the vac source BTW? curious. Just give up. Honestly. If this shit's causing this much of a head ache for you THEN QUITE. Because boost isn't going to treat you nice 100% of the time. And BTW. Why are you bumping your post after 15 minutes? |
Re: Help! (racinskittle)
Yeah it is hooked to the brake booster I belive. And I have an RFL. And sorry for whining man it's been a long week and I have been annoyed by minor things, but boy o boy that boost is sweet (what I felt of it lol) https://honda-tech.com/forums/images...es/emsmile.gif
Re: Help! (tolowhb)
lol no prob. Im in a bad mood too haha. I can't get my mind off of school and work https://honda-tech.com/forums/images/smilies/emsad.gif
Good luck with it man! Sorry I had to share my anger w/ya, but i guess you were the lucky one https://honda-tech.com/forums/images...s/emsmilep.gif haha. Take it ez! OHH it's because you're hooked up to the brake booster that you see that rise on the boost gauge. https://honda-tech.com/forums/images...es/emsmile.gif It wont hurt anything. |
I have it hooked directly off the booster, I just read I should hook it up closer to where the line goes into the Intake manifold, does this sound right?
Re: Help! (tolowhb)
Hey guys, I got everything fixed, turns out tee directly off the brake booster messed my bov and gauge up! I am much more happy now!
| All times are GMT -8. The time now is 07:18 AM. |
