hello, and my dyno graph
Like to say hello to all here, i am new to the world of FI.
I bought a Drag 3 kit for my gsr, installed it ran it went to tune it, and wideband showed numbers of 17:1. quick story, rings went down the *******.
had a spare b16 laying around from my ef, so i threw it in. Bought a F.A.S.T stand alone ecu and got it set up.
SO my set-up right now - 1st gen B16a,CTR cams, AEM cam gears, Drag 3 kit with Tial 35mm wastegate with .5 bar spring(i was told) 2.5inch dp, 3 inch hi-flo cat and exhaust. F.A.S.T ecu, msd 6a, RC 440cc injectors.
cam gears are set to 0 degrees.
Re: hello, and my dyno graph (Blown90hatcH)
im going back next week, get a printout of my a/f
vtec well we just put a 5100 pill in there.
Remember I am new to this FI stuff so all this info is GREATLY appreciated!!!!
Re: hello, and my dyno graph (Phat_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phat_GSR »</TD></TR><TR><TD CLASS="quote">im going back next week, get a printout of my a/f
Remember I am new to this FI stuff so all this info is GREATLY appreciated!!!!</TD></TR></TABLE>
Dyno the low speed cam, dyno the high speed cam and see where the trq curves cross. Also, I would look at dialing those cams in as well with those adj cam gears.
You can control the crossover points...so, I'd think you could graph a range where the curves would cross, ie, really low and really high vtec x-over points.
Also, backing up the "damn" on the 17:1 AFR...sounds like fmu no worky to me.
That's nucking futty lean .
My assumption is that your loosing some of your boost because of the cams. ITR cams are about MAX you want to run IIRC - I think CTR cams are too much overlap.. You may want to consider swapping back in your GSR cams and going for a re-tune. Thats just my .02
Re: (turboteg2nv)
it is stand alone, its awsome caus enow we can adjust everything by as little or as much as we need.
as far as downgrading to the b16, yeah i felt the diff. but oh well cause the gsr block is getting built now so, I just keep remindng myself its temporary.
Re: (Phat_GSR)
So if you have a stand alone ecu why are you using the rpm
pills. shouldn't that be adjustable. if not how are you tuning
your high and low maps.
Re: (Phat_GSR)
Well I didnt know until I saw your thread today and remembered your lic. plate
your from guelph..put the 2 and 2 together..made sense to me
and I have an eye for turbo hondas since mine was once.
i was in a black SiR. didnt run to hawt. couldnt hook up worth a damn although azenis arent really drag tires.
15.00@93 mph was my best. was hoping for high 14's but it wasnt to be. (traps are there though)
Re: (SiRkid)
yeah i saw you run a couple times
with the stand alone that i have i guess that theres no vtec settings so im using an MSD acttivated switch.
