heater hose oil drain?
Old 03-08-2006, 08:09 AM
huge230's Avatar
Default heater hose oil drain?
What temp. is heater hose good for? Anyone ever use it for an oil drain?
Old 03-08-2006, 08:10 AM
boostincoupe's Avatar
Location: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
Default Re: heater hose oil drain? (huge230)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by huge230 &raquo;</TD></TR><TR><TD CLASS="quote">What temp. is heater hose good for? Anyone ever use it for an oil drain?</TD></TR></TABLE>
I've been running a heater hose for an oil drain for 3 years now, it works fine
Old 03-08-2006, 08:12 AM
ham
ham's Avatar
you should use some pushlock hose, like -10 or whatever will squeeze hard onto the hosebarbs. you wont need any clamps and it is much more durable.
like this
Old 03-08-2006, 08:15 AM
huge230's Avatar
Default Re: heater hose oil drain? (boostincoupe)
ok, do you guys know what kind of heat it should eb good for? Mine will have to run fairly close to my manifold because of hows its setup
Old 03-08-2006, 10:17 AM
mike1114's Avatar
run a firesleeve over it. It will keep the temp out. It can withstand a molten lava splash. I have more of it on my catch can set up and the firesleeve is literally SITTING on top of my ramhorn manifold.
I even have a firesleeve on my stainless steel oil return line since it does come near the exaust and dumptube. (exhaust is thermal wrapped though)
Old 03-09-2006, 02:55 PM
usdm ws6
Guest
Posts: n/a
Default Re: heater hose oil drain? (mike1114)
i've been using just the normal advanvce auto parts heater hose for my oil return for a few months now...no problems except 1 instance it got warm enough that it kinked a little, but i got another one and it has worked fine since
Old 03-09-2006, 04:02 PM
Sketch_hs's Avatar
get the steel braded line and use push lock fittings
hard to get on but works grreeeeat
Old 03-09-2006, 04:05 PM
Bailhatch's Avatar
Default Re: (Sketch_hs)
Have you guys ever seen a radiator hose that has been soaking in oil and all bubbled out and squishy?
Old 03-09-2006, 04:12 PM
D@nnY's Avatar
Default Re: (Bailhatch)
your retarded if you use regular hoses for oil
Old 03-09-2006, 04:24 PM
I AM A SCAMMER, DO NOT BUY ANYTHING FROM ME.
JUST2SPOOL's Avatar
Default Re: (D@nnY)
To some it works others it doesnt but in this hmt world the possibilities are endless hehe
Old 03-09-2006, 04:30 PM
D@nnY's Avatar
Default Re: (JUST2SPOOL)
no it doesnt work...try using a hose that wasnt made to hold oil and see what happens to it.....after which it breaks and you loose all your oil
Old 03-09-2006, 04:56 PM
CRXDrew's Avatar
Don't do it. Get hose meant for oil transfer not **** that is "oil resistant".
One day its gonna pop on the freeway and then you're in trouble
Dave_Dc2
06-19-2010 03:56 PM
cruiseMain
04-12-2008 08:36 PM
K i l l a B e e.
09-30-2007 03:41 PM
scartail
08-08-2004 04:20 AM
lsvtec101
01-19-2003 12:17 PM
Quick Reply: heater hose oil drain?
