Honda-Tech - Honda Forum Discussion (https://honda-tech.com/forums/)
-   Forced Induction (https://honda-tech.com/forums/forced-induction-16/)
-   -   having cooling problems (https://honda-tech.com/forums/forced-induction-16/having-cooling-problems-373208/)
RuthlessEF-9 Jan 1, 2003 01:42 AM
ever since i put my turbo on in my 89 civic 4dr i've been running on the really warm side. you think if i run thermal wrap on my DP would keep my temp down
LsVTeCTuRBo17 Jan 1, 2003 01:47 AM
Re: having cooling problems (D16z6turbs)
Yea it may but not drastically. Does it over heat? How much of the overheat gauge is reading?
Turbo motors are known to be a little more on the hotside. Also are you using a stock radiator, if so swap that out and get a fluidyne.
[Modified by LsVTeCTuRBo17, 2:48 AM 1/1/2003]
RuthlessEF-9 Jan 9, 2003 08:54 AM
Re: having cooling problems (LsVTeCTuRBo17)
it doesnt overheat but i got a spoon radiator cap and that seem to help me out
so thanks for the help
Doodoo Jan 9, 2003 10:54 AM
It shouldn't overheat unless your cooling system is jacked up. I have an 88 and it only overheated when something wasn't working right. Check fan, thermostat, coolant, radiator cap, and radiator for any faults.
