has anyone ordered the turbo oil line kit from turbo performance??
http://www.turbo-performance.com/Pro...l-linekits.htm
pretty cheap at 75.99+s/h for the full kit..return,and feed with all fittings..watcha all think?
Re: has anyone ordered the turbo oil line kit from turbo performance?? (GOLDBERG)
I got my Oil Return from South Florida Performance for $40, and my feed from http://www.secureperformanceorder.co...6&CategoryID=3 for $30 or something like that.
Good prices and service
[Modified by johnisenglish, 11:07 PM 1/11/2003]
Re: has anyone ordered the turbo oil line kit from turbo performance?? (johnisenglish)
those fittings are crap. go with some earl fittings and ss braided lines. you could try jc whitney or summit. they should have what your looking for. ill try to find the post for the fittings that you will need. some people had bad experiences with them also, just to like you know.
Re: has anyone ordered the turbo oil line kit from turbo performance?? (wickedxboi)
Those fittings are fine. You dont need Earl's, although they are better. Go to a plumbing store, it is cheaper.
Re: has anyone ordered the turbo oil line kit from turbo performance?? (SlowB16)
i had ordered the -4 braided kit from autometer with fittings, everything fit perfectly and it was a tad bit cheaper than buying the fittings and line (thats for the sending only) i made my own return line
Re: has anyone ordered the turbo oil line kit from turbo performance?? (PROFILEGSR)
either way is fine...sometimes the clamp on style may be easier to route than standard earl's hose ends...but if you can live with a few drop of leaks, it'll be fine...
I'd get a performo-flex lines though...most cheap braided lines have crappy coating on the rubber inner lining and it may clogged the lines....so get a performo flex. on the oil feed line, get a teflon coated lines, with the small size, you need to have a teflon base inner lining to prevent clogging...
stan
stan
senior gold member
What about NOS lines? I ordered my feed from them for 35 bucks. Its teflon coated.
Re: has anyone ordered the turbo oil line kit from turbo performance?? (Ivan)
i believe viren sells the kit (return and feed) for $145.............i planned on buying off of him.....maybe not any more
