has anybody seen this setup for Turbo
Re: has anybody seen this setup for Turbo
i got it done at a local shop in jacksonville NC. The weld looked a little sketchy, but i didnt think much about it until i started checking other peoples setups.
well i think that elbow is more designed to attach between the mani and wastegate (for hood clearance) but that setup should be fine, there's just an extra flange in there making it look a little busy
alright...thank you for clearing that up for me..i was a little worried
The only other thing you could do is get a rotation adapter plate. It bolts on between WG and mani, but has 2 extra holes 90* from the manifold's holes. The dump tube flange would then bolt on the side for a straight shot to the dump tube.
Currently yours will be fine, just not the most professional looking. If you really cared, you'd be getting a full-race manifold, tial 44mm, etc...
Walterronny
Welding / Fabrication
04-01-2013 03:49 AM
anybody ever use the wastegate hole off a turbo and plumbed it to the wastegate instead of from turb
Prelude91siT
04-14-2004 06:55 PM
is3oo
Audio / Security / Video
07-15-2003 11:25 AM
TempBS
03-12-2003 06:57 PM
