Hard Time Starting After Filling Gas: Anyone else have this problem?
Hey just wondering if anyone has a hard time starting there car after they fill up. I have a boosted civic, walbro pump, aem fuel rail, regualtor, etc....car is fully tuned runs great, just after i fill up it takes about a minute it seems to build pressure and run again. Weird! Anyone ever experience this?
Re: Hard Time Starting After Filling Gas: Anyone else have this problem? (XX Boosted Si XX)
it almost sounds like ur talking about flooding the motor. Does it do it when u drive your car, turn it off, then try to turn it back on 2-3 min later (without filling up)?
Re: Hard Time Starting After Filling Gas: Anyone else have this problem? (adictionbass)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">it almost sounds like ur talking about flooding the motor. Does it do it when u drive your car, turn it off, then try to turn it back on 2-3 min later (without filling up)?</TD></TR></TABLE>
nope only does it when i fill up..lol seems as if all the pressure is released in the lines and it takes a min to build up its weird
next time you go to fill up, turn the key to the on position without turning the car on (2 clicks). You'll hear the pump come on then the sound will stop. (maybe 5-10 sec.) then turn the key the rest of the way, see if it still does it.
Re: (igo4bmx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx »</TD></TR><TR><TD CLASS="quote">let me guess you're running and obd1 ecu on an obd2 motor?
disconnect the evap purge solenoid</TD></TR></TABLE>
yah i run hondata ...is that the problem?!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass »</TD></TR><TR><TD CLASS="quote">next time you go to fill up, turn the key to the on position without turning the car on (2 clicks). You'll hear the pump come on then the sound will stop. (maybe 5-10 sec.) then turn the key the rest of the way, see if it still does it.</TD></TR></TABLE>
ive done that before it helps....but not always
So you just disconnect that plug? DO you just leave it like that open?
Be careful when you unplug that, i did the same thing and all it did was lead to a terrible vac leak, engine revved really high and i shut it down.
TibTeg
03-30-2008 12:55 AM
baonest1
08-18-2003 11:22 AM
